A/C Compessor Swap
Old Jun 17, 2006 | 12:35 AM
rlay302's Avatar
rlay302
A/C Compessor Swap
Has anyone made the swap to the newer a/c compessor? I've already converted my 79' F-150 to 134. I'd like to put on a newer compessor say like off a 2000 and up truck.
Old Jun 17, 2006 | 10:48 AM
classic79's Avatar
classic79
the york style on there now is better, and more durable. no need to change it.
Old Jun 19, 2006 | 12:05 PM
Purely Ford's Avatar
Purely Ford
There are higher cfm york style ompressors than the stock ones used in these trucks. Just get one like have been used on big rigs with sleeper cabs. I have one that I've used until the AC system developed a leak (probably an O-ring). Anyway, the inside of the cab got too cold and would cause the windows to sweat on the outside (condensation).
If you can find one, you will probably need to change the head on it over to the type that has the threads like your fittings/hoses use. Also, these all use the same length shaft so the pulley and clutch you have will bolt right on. You may need to use the electromagnet on your old compressor because of fitment/spacing issues.
There is a website that shows all of the details about these compressors. I'll see if I can find it again and post it here.
Old Jun 19, 2006 | 08:08 PM
79driver's Avatar
79driver
i havent made the swap, but i want too. i havent found much info about it or seen anyone with a different than stock compressor. I would like something smaller, lighter, r134a compatible, and something that takes less power to turn. let me know what you end up doing
Chasvan
Nov 10, 2012 10:56 PM
f350Super99
Jul 21, 2009 11:07 PM
jrs_big_ford_f150
Jul 9, 2003 04:35 PM
Goodold71
Sep 4, 2002 11:06 AM
FS88Bronco
1978 - 1996 Big Bronco
Aug 9, 2001 12:28 AM
