Which transmission...
Old Sep 20, 2001 | 04:34 PM
Bill_Beyer's Avatar
Bill_Beyer
Which 4 speed, non-synchro 1st & Rev, granny low transmission would have come in a 60s pickup with an FE engine? Anybody know the number?
Old Sep 20, 2001 | 06:29 PM
benford's Avatar
benford
The New Process 435 transmission was used in Chrysler (1963-1993 ), Ford (1964-1987 ) and G.M. (1963-1972 ) trucks. These transmissions have a 6.68 to 1 1st gear ratio in all three applications. While Chrysler and G.M. applications also offered a 4.56 to 1 ratio. The Ford versions adapted real well into the early Broncos (1966-1977 ) and late Jeep CJs (1980-1986 ) with only minor modifications. While other conversions require more modifications including drive shafts lengths. The NP 435 is a HD transmission with cast iron case and aluminum cover. It is synchronized 2nd through 4th gear with sliding gear for 1st and reverse. They ran a solid cluster on needle bearings and a tapered main drive gear bearing on most applications. Our rebuilt transmissions include all new bearings, seals, gaskets and whatever it takes to make them a good reliable transmission. These transmissions are available as stock replacement or as conversions
Thought this might help.
Benford
Old Sep 20, 2001 | 08:33 PM
FE427TP's Avatar
FE427TP
Pull up the dust boot, if the shifter is held in by a stamped aluminum piece that pushes in (hard) and twists then it's a NP435, if it threads off them it's probably a Borg Warner T-18
Old Sep 20, 2001 | 11:10 PM
Bill_Beyer's Avatar
Bill_Beyer
OK...so who's familiar with a 3 speed non synchro, granny low first Ford tranny which will mate up to an FE?
Old Sep 21, 2001 | 12:12 AM
Tomohawk's Avatar
Tomohawk
Kestas
1983 - 2012 Ranger & B-Series
Oct 10, 2012 07:51 AM
72SMITH
Dec 3, 2008 05:43 AM
John7894
Jul 14, 2002 06:43 PM
slick78
Feb 21, 2002 11:44 PM
