Which transmission
Old Oct 9, 2012 | 09:04 AM
Kestas's Avatar
Kestas
Which transmission
Which transmission came with the 1987 Ranger 2.9L?
Old Oct 9, 2012 | 10:35 AM
smokenchoken's Avatar
smokenchoken
i believe a4ld at least i know that is what is in my 88 w/2.9L.... why are you having issues or looking to get one? let us know the scoop Kestas
Old Oct 9, 2012 | 11:43 AM
Kestas's Avatar
Kestas
No scoop - my coworker just bought this vehicle. I'm not sure why he needs to know the type of transmission.
Then truck presently has a clunk in the drivetrain. It's noticeable when toggling between drive and reverse. There's no excessive movement of the engine, which indicates the motor mounts are fine, and he says the u-joints are fine. I guess that leaves the transmission or rear axle.
Old Oct 9, 2012 | 11:47 AM
smokenchoken
that is probably the rear end going out most likely if it is not u joints like i would suspect it should not be in the tranny IMHO
Old Oct 10, 2012 | 07:51 AM
tomw's Avatar
tomw
Crawl under, or alongside, and watch the show as the selector is moved from gear to gear. You will likely see the driveshaft move a bit in either direction as all slack in the drivetrain is taken up. Unless it is severe, it is not a major source of worry. It would be a good idea to check the differential for proper lube & level. FWIW, I have an old one that had never needed transmission lube added every time I checked. Took it on a trip, and it, or something, started to smell hot as I neared home. The transmission was down, and I assume that it was a very slow drip from the speedo cable adapter, which has leaked since it was new.
tom
‘67fairlaneGta
May 15, 2018 06:38 PM
ErrorS
1978 - 1996 Big Bronco
21
Oct 2, 2010 12:25 PM
GammaDriver
Oct 12, 2004 12:23 AM
Frozen1
Aug 18, 2003 10:29 PM
Seifferlein
Sep 3, 2002 05:54 PM
