Help Help !!!!!
Old Jun 15, 2006 | 11:22 PM
hawaiiguy808's Avatar
hawaiiguy808
Help Help !!!!!
OK HI IAM NEW SO HERE GOES I HAVE A 79 F250 WHEN I START IT IT RUNS GOOD BUT THEN YOU TAKE IT OUT FOR A DRIVE THEN IS STARTS TO BOG OUT AND THEN QUITS AND HARD TO START ORR IT WILL RUN GOOD FOR 15 MIN THEN ACT UP THIS IS WHAT I HAVE DONE SO FAR I REBUILT THE CAB,CLEAN PLUGS ,CAP,ROTOR AND REPLACE THE RUBER HOSE AT THE BACK OF THE TANK AND NEW FUEL FILTER HOSE AT FUEL FILTER LOOKS GOOD AND A NEW FLOAT TO DAY THE FULL PUMP WILL FILL S SMALL BOTTEL OF WATER IN 5 SECOUNDS (IS THAT GOOD) SO WHAT ELES? AND AS OF TODAY I JUST PUT IN A NEW ENG BLACK BOX BUT NO LUCK SO I REALLY NEED SOME XPERT HELP HERE!!!!!!!
Old Jun 16, 2006 | 12:23 AM
FTE Trigger's Avatar
FTE Trigger
Welcome to FTE Hawaiiguy....!
Lets see if we can get a moderator to help move you in the right forum and get some ideas moving for your troubled F250.
Old Jun 16, 2006 | 05:24 AM
Beast12's Avatar
Beast12
Hi and welcome to FTE! I moved your post to the 73-79 F-Series truck forum where you will get more help.
Read this for some info that will help you around the site: https://www.ford-trucks.com/forums/s...92&postcount=2
-Matt
Old Jun 16, 2006 | 09:25 AM
Mil1ion's Avatar
Mil1ion
Aloha, Welcome to the site
Sorry I can't help you because I can't read your post
You used "upper case" and I don't know what the topic is because it isn't in the title
Btw, Upper Case is consdered Yelling
and I don't know why Matt never edited it out
I can help you understand what to do on FTE though when posting to make it easier for everyone here.
Maybe start with reading post #1 on this thread labeled Read First:
https://www.ford-trucks.com/forums/s...d.php?t=102632
Old Jun 16, 2006 | 09:32 AM
Mil1ion's Avatar
Mil1ion
Now in Lower case:
Quote:
hi iam new so here goes i have a 79 f250 when i start it it runs good but then you take it out for a drive then is starts to bog out and then quits and hard to start orr it will run good for 15 min then act up.
This is what i have done so far:
1) i rebuilt the cab,
2) clean plugs,cap,rotor and
3) replaced the rubber hose at the back of the tank
4) new fuel filter hose at fuel filter
looks good and a new float today
the fuel pump will fill a small bottle of water in 5 seconds..... is that good?
so what eles ?
as of today i just put in a new eng black box but no luck so i really need some xpert help here!!!!!!!
Sounds like bad fuel or fuel filter.
Even though you changed it.
The engine needs 3 things to run:
1) Air
2) Fuel
3) Spark at the correct time
How many miles on this engine ?
After the engine bogs down and quits ,with engine off did you check the carb to see if it squirts fuel ?
Where do you have spark?
at coil
at plugs
at wires
Old Jun 16, 2006 | 10:19 AM
olfordsnstone's Avatar
olfordsnstone
Seems like fuel filter or bad fuel to me.
(like Mil1on said)
On the 79, isn't there something else with the spark too Dennis? I have a points ignition but I remember you earlier stating something about a control modual or something like that for a similarly stated problem a year or so ago.
Old Jun 16, 2006 | 10:44 AM
Mil1ion's Avatar
Mil1ion
I think what he calls a black box means what is really the I/M.
So many times the problem is just a wire coming loose or just corroded.
He doesn't say whether he fiddles with the wiring/connection or anything.
So right now, it's just a guess.
