Sponsored by: Auxito
gears
Old Jun 15, 2006 | 01:31 PM
02 LariatFX4's Avatar
02 LariatFX4
gears
All this talk about 4.10 gears being put into your vehicles has me considering it seriously....but only one worry...and I haven't found or if i did remeber how much gas mileage I will lose on the highway with this change...What are the differences on the highway at 60 -65MPH in overdrive RPM wise?
And will it give the truck more acceleration from a stop without the load too?...
Old Jun 15, 2006 | 03:07 PM
MBDiagMan's Avatar
MBDiagMan
The engines of today make their torque peaks at a significantly higher RPM than the older engines. This means that when going to a lower gear you are actually moving closer to the torque peak which is the most efficient speed of the engine. Your fuel mileage will not fall off and could even improve with a lower gear. This doesn't, however, mean that you can go to 5.88's or something without losing fuel mileage, but a slightly lower (higher numerically) gear will probably not hurt anything.
Good luck,
Old Jun 15, 2006 | 11:37 PM
LxMan1's Avatar
LxMan1
I believe that you will only see about 400 to 500rpm more @ highway speeds.
Green72F250
Jul 8, 2014 03:34 AM
Truck Guy99
Feb 5, 2014 06:00 PM
kilich
13
Aug 13, 2012 01:07 AM
4x4bigblock
Feb 23, 2006 10:41 PM
fire4335
Jan 7, 2004 06:23 PM
