Axle gear swap necessary?
I plan on getting a 6" lift kit and 37" tires this year. I still want to drive it on the highway often but take it mudding on weekends too. Will 4:10 gears work for driving at highway speeds with thus setup or do I need to swap gears?
Truck is 88 F350 with 460 and C6 trans
Ok, well if it's a daily driver, I have several points you may want to consider.
A lift and tires are going to hurt your MPG, and I'm sure it's bad already being a 460 without over drive.
A 6" lift is way too much if you are only putting 37" tires on it, as you can usually fit 35" tires stock with a little bumper trimming. A 2" lift would probably be fine.
With that said, 4.10 is probably a good ratio if you do highway driving a lot without O/D and wheel just a little.
crucialprospect
07-28-2017 02:18 PM
kenpobuck
26
09-22-2011 12:38 AM
