urban legends that actually work
Old Jun 15, 2006 | 09:46 AM
Downriver Thunder's Avatar
Downriver Thunder
Say your keys get locked in your truck and your keyless pad doesn't work, here's an urban legend that works, I tried it.
I called my cell, set it on speakerphone and layed it on the running board of my Excursion. I walked back to my office, far enough away that the remote won't reach and hit the button, walked back out to my truck and sure enough it was unlocked! I wouldn't believe it until it worked.
Old Jun 15, 2006 | 09:48 AM
Matt M, PA's Avatar
Matt M, PA
Huh? Hit what button?
Old Jun 15, 2006 | 09:53 AM
Downriver Thunder
Just what it says, try it. call your cell, set to speaker and lay it on your running board. Go back to the phone you used to call and put your remote next to it and hit your button then go check your truck, it should be unlocked, mine was.
Oh, I forgot to put the link in, sorry.
http://www.snopes.com/autos/techno/keyless.asp
Old Jun 15, 2006 | 09:59 AM
Matt M, PA's Avatar
Matt M, PA
Oh..hit the button on your remote.
If I lock the keys in my car...the remote will be with them. I suppose it would be good for a lock-out if someone at home could call your cell and use one of the other remotes.
Old Jun 15, 2006 | 10:01 AM
Downriver Thunder
Yep, that's what is supposed to happen, check the link. It works for those who don't have the keypad on the door.
Old Jun 15, 2006 | 11:43 AM
rlh68050's Avatar
rlh68050
I would normally say BS, but it may be possible for the RF to piggyback onto the cells signal. Try it from a greater distance, like a mile away and see what happens.
Old Jun 15, 2006 | 11:51 AM
Downriver Thunder
You're probably right with the piggyback theory.
Old Jun 15, 2006 | 02:43 PM
ryaneverk2's Avatar
ryaneverk2
Pretty darn cool... I'll have to go try this after work.
Old Jun 15, 2006 | 10:22 PM
bmenzel's Avatar
bmenzel
I'll try it tomorrow and post the result.
Old Jun 16, 2006 | 03:25 AM
SmokinJohn's Avatar
SmokinJohn
If your keys are locked in your truck, how do you have the keyfob?
As an aside, if you press your keyfob firmly under your chin while hitting a button, you can double or triple the range of the signal. Wierd, but true!
Old Jun 16, 2006 | 06:27 AM
Matt M, PA's Avatar
Matt M, PA
SmokinJohn...it's called body induction. Same way often holding a TV or radio antenna brings in a better signal.
Funny aside...I dated a particular girl twice. The first time we were together...many years ago...she laughed when I would use the remote at my chin. The next time we were together..7 years later...she admitted to trying same and feeling like an idiot for not beleiving me. (What a lasting impression I make)
Old Jun 16, 2006 | 06:54 AM
jade97's Avatar
jade97
I bet if you tried it from across town, it would not work.
The remote does not work on sound frequencies (below 20 kHz).......
Old Jun 16, 2006 | 09:29 AM
wabiker's Avatar
wabiker
....whats a cellphone??
Old Jun 16, 2006 | 10:25 AM
westwurd's Avatar
westwurd
Should you have posted the Snopes link?
I love snopes.com! I followed the link in the original post - Snopes says this is impossible. They said you are probably still close enough for your key fob to be working. Has "Myth Busters" tried this one?
Old Jun 16, 2006 | 11:03 PM
Btravelen's Avatar
Btravelen
I don't get it. ??? The link you reference says this is BS, but you say it works for you??
