Zf-6??
Old Jun 17, 2006 | 11:00 PM
M14-slamfire's Avatar
M14-slamfire
Originally Posted by F350JOHN
Where is this truck compaired to your location? That sounds like a heck of a drive.
Maybe you should wait and see, because it always works out that when you buy one across the country, one will pop up just down the block from you!
He's in Oregon, I'm in Tx. have to wait now anyway. The tranny works ok when it heats up, and I dont use the truck much now anyway. Sometimes when it's cold, the OD light blinks when breaking and the truck does'nt down shift, It pushes forward like it wants to take off, Happens in reverse also.
Old Jun 18, 2006 | 07:08 PM
Dave Sponaugle's Avatar
Dave Sponaugle
There are ratio calculators for the transmission ratios on the gear vendors and us gear sites.
The Gear Vendors has a lockout that prevents the unit from engaging overdrive when the transfer case is in either low or high 4x4 to prevent driveline damage. Yes you could bypass or override it, but it would only take one mistake to cost a lot of money to fix the damage if you forgot to check the front hubs.
Old Jun 18, 2006 | 10:37 PM
AndysFords's Avatar
AndysFords
I saw that truck in Oregon in the classifieds, but decided to just let it stay there. Its a long way from Arkansas.
Old Jun 19, 2006 | 09:44 AM
M14-slamfire
My truck does'nt have locking hubs. Right now the number I'm getting to rebuild mine, rather to fix what's wrong, is $2,200. I only drive the truck about once a month, though if it were righteous, I would use it more often. People here talk about a off road tranny builder over in Ar. Does anyone remember who that is? Btw, this problem is happening when I have the truck in 2wd. I don't put it in 4wd 'cause I don't want to mess it up more. I do drive over curbs and median strips between buisnesses to bypass the roads when I feel like it!
Old Jun 22, 2006 | 01:13 AM
Dave7.3's Avatar
Dave7.3
I have a 1991 F250 XLT 2wd with a ZF5 trans and 4.10 gears. Would it be easier and/or cheaper to buy a ZF6 or to invest in a Gearvendors unit? I see GV units around every once in a while for $3000 down to $1000. On the other hand there are ZF6's online for around the same price or cheaper, problem is they are for years 99 and up. Would they bolt up even with the vast year difference? if they do, then what would have to be done between the tranny and the rear axle to make it work?
Old Jun 22, 2006 | 08:37 AM
Hamberger's Avatar
Hamberger
Unless you get a deal on the ZF6 or GV unit, by the time its installed the cost would probably be about the same.
The GV unit behind your ZF5 would give you a double overdrive, the ZF6 only give you an extra gear with approximately the same OD ration as you already have.
You need to stick with the GV unit that was designed for your transfer case (1356 I believe)
Old Jun 22, 2006 | 06:48 PM
F350JOHN's Avatar
F350JOHN
Wink
As stated earlier, the speedometer hookup/location is totally different on the ZF-6. I believe the 1999-200X ZF-6 equipped trucks have the speedometer reading run off the rear end instead of the ZF-5 which has that little plug at the transmission.
Old Jun 22, 2006 | 06:56 PM
F350JOHN's Avatar
F350JOHN
On a 7.3L diesel the bolt pattern is the same, so it would bolt right up, but between the speedometer hookup being different as mentioned above, and the slave cylinder is totally different, its one of those internal slave/throughout berring combos, which would require all new fluid pipeing and fittings, the crossmember is different too.
So I don't think it would be worth it.
However, it has been done before...........
Old Jun 22, 2006 | 07:05 PM
AndysFords's Avatar
AndysFords
You can order a different input shaft from Gear Vendor for $650 to change it to anything you need it to fit. All Gear Vendors are the same, whether its behind a 68 mustang or an 01 Excursion.
Old Jun 22, 2006 | 07:47 PM
Dave7.3's Avatar
Dave7.3
I am now considering buying a US gear auxilary overdirve considering that it can be used at any time. Just my choice really because having a double overdrive would be great for interstate speeds.
'97f350supercab
Dec 4, 2016 08:06 AM
'97f350supercab
Engine Swaps
Oct 12, 2016 05:58 PM
Pele
Aug 31, 2016 12:38 PM
XBAJBUSX
23
Oct 22, 2014 06:43 PM
f300i6
Aug 7, 2014 04:25 AM
