Smoke from the dash
Old Jun 14, 2006 | 08:27 AM
jimmer-48's Avatar
jimmer-48
Smoke from the dash
Hey All!
I have an 86 F-150, 4.9L I6. I replaced the thermostat a few months back b/c I was over heating when idling.
Every now and then, I get a white smoke from my defrost vents and under the dash. I think it may be my heater core. Is this correct?
Thanks!
Jim
Old Jun 14, 2006 | 08:42 AM
Jeff Fisher's Avatar
Jeff Fisher
Heater core for sure.
Old Jun 14, 2006 | 08:51 AM
jimmer-48's Avatar
jimmer-48
Is it safe to drive? I'm supposed to go camping this weekend.
Old Jun 14, 2006 | 08:58 AM
Sycostang67's Avatar
Sycostang67
I believe there are also some resistors under the dash, and debris can collect on them and burn. Does the smoke only comeout when the heater is on or can it happen anytime? Does it smell electrical or chemical?
Old Jun 14, 2006 | 09:00 AM
jimmer-48's Avatar
jimmer-48
It smess more chemical. When I put the defrost on it does get worse. Also, when the smoke hits the window, it's difficult to get off. It's not like steam.
Old Jun 14, 2006 | 09:21 AM
Jeff Fisher
I would not take it out like that. Breathing coolant can't be good, and you will be constantly loosing coolant.
Camping is important, I would do this: You can easily disconnect the supply and return hoses from the heater core and join them together with a union connector and be good to go. Fix it when you get back. Of course you are then without a heater, but it's summer time, who needs heat.
Jeff
Old Jun 14, 2006 | 09:24 AM
Jeff Fisher
While your picking up the union at the parts store be sure to grab some heater hose too. Very possible that the heater hoses are in need of replacement. This kind of stuff happens when coolant gets low, you get higher pressures, the higher pressures tend to make old parts fail.
When you get back from your trip do a thourough inspection of your radiator, radiator hoses, heater hoses and replace that heater core.
There is absolutely no question in my mind, having seen this exact thing more than once, your heater core is leaking.
Good luck,
Jeff
Old Jun 14, 2006 | 09:29 AM
jimmer-48's Avatar
jimmer-48
Thank you!
Old Jun 14, 2006 | 03:27 PM
big302's Avatar
big302
I have a new heater core for sale if need one
Old Jun 14, 2006 | 04:19 PM
big hoss 29's Avatar
big hoss 29
You know, it's not that hard to replace a heater core and it would make a lot more sense than plugging it off until after the trip. It should only take you an hour at the most to change it out.
The only reason I'm saying this is if you don't have time to fix it right, when are you going to have time to do it again? Here in Montana, it can get cold in a heartbeat. I've seen it be 80* one day and the very next it was snowing, so you never know when you need your heater.
Old Jun 14, 2006 | 05:11 PM
sierraben's Avatar
sierraben
If it smells like burnt sugar, then it's probably coolant.
Could also be a bad hose or a loose clamp.
Just replace the heater core, if time permits.
Old Jun 14, 2006 | 05:22 PM
jpjahn's Avatar
jpjahn
Yeah, I'd just replace it. I'm not sure if it has the same setup as my 85 F150 351, but I think its easier to replace than I made it. I ended up having the whole dash out, then realized that there were just a few nuts or bolts in the engine compartment to undo. Also 2 or 3 inside maybe?
As far as breathing in the coolant... The last job I had we used a 88 Econoline van. One of the hoses was unsnapped from the heater core, so the coolant was leaking into the cab on my side, as well as steaming up the cab. The guy that drove the van was too lazy to fix it, so it went on like that until I got tired of breathing that stuff and getting my feet soaked every morning. I ended up fixing it all myself, just by doing alittle exploring.. took just a couple minutes.. I hated that job! I also wasn't geting paid for overtime, even though I had overtime every week... Whoops.. sorry... I'm still just alittle mad... Lol
Have fun camping!!
Old Jun 15, 2006 | 08:14 AM
jimmer-48's Avatar
jimmer-48
Hey thanks for the advise!
It was definitely the heater core causing the problem. I bypassed it last night, put more coolant in and I was cool all the way to work this morning and more importantly, no fog in the cab!!
As I don't have time this weekend to change it, I definitely will next weekend. Does anyone know how to tell if it's a "high flow"? The NAPA guy told me there are two showing up for this truck.
By the time I get done with this thing it'll be like a brand new one!
Much Thanks!
Old Jun 15, 2006 | 11:55 AM
Mudman's Avatar
Mudman
If you don't have ac, the outside of the box, inside the engine compartment will say High Output where the heater core sits. The high output core are a little longer than the standard core.
Old Jun 15, 2006 | 04:56 PM
sharpster68's Avatar
sharpster68
i have a 85 F150 with AC and the heater core for mine cost like $25.00 from Kragen auto parts bought it about 1 year ago, only took about and hour and no dash disasembly was required except removing the glove box.
