Noise under Load
Old Jun 13, 2006 | 11:57 PM
7.3NUT's Avatar
7.3NUT
Question Noise under Load
I was pulling 14k 5th wheel up the mountains and under load, about 25 boost,
1200 ET and I hear a noise like a rattle when at giving it more on the throttle.
When I let off it goes await. No notice of lost power just the rattle noise.
Any body run across this ? I am hoping not turbo problems!
1999 F350 Preditor,4in exhaust,3 guages,shift kit, exhaust brake,Tran lock.
Old Jun 14, 2006 | 07:25 AM
Kwikkordead's Avatar
Kwikkordead
What RPM, gear?
Perhaps your stocker intake wheel was stalling? Mine would with just a stock tune pulling that kind of weight, never mind having the Tow/haul mode loaded in.
Old Jun 14, 2006 | 11:02 PM
jtharvey's Avatar
jtharvey
Is what you call a rattle a slow rattle or a quick one? Could be like kwik said, just a turbo stalling under load.
Old Jun 14, 2006 | 11:19 PM
Tenn01PSD350's Avatar
Tenn01PSD350
What is this turbo stall under load?
Old Jun 14, 2006 | 11:34 PM
jtharvey's Avatar
jtharvey
Same thing as turbo flutter that the WW or ATS housings cure.
Old Jun 14, 2006 | 11:43 PM
Tenn01PSD350
Ahhhh, turbo flutter. I'm with you now.
Old Jun 19, 2006 | 12:45 AM
7.3NUT's Avatar
7.3NUT
Exclamation Turbo Flutter
RPM around 2200 to 2600. What is the fix for Turbo Flutter? About How much is the cost. It was also in 3rd out of O/D......
morris_506
1997 - 2003 F150
15
Jul 30, 2023 02:53 PM
Joe Wilder
Apr 6, 2012 10:23 PM
jerseyjeff1978
3.8 & 4.2L V6
Sep 9, 2011 11:07 PM
crazandy
23
Mar 20, 2005 12:11 AM
4X4X460X76
Nov 13, 2002 07:16 PM
