My EBPV stuck shut. Problems????
Old Jun 13, 2006 | 06:31 PM
trike1946's Avatar
trike1946
Question My EBPV stuck shut. Problems????
When I started to drive home from work today, the truck did not seem to run right (my 97). The more I drove the more it ran worse. I drove about 30 miles and just about got home. After it cooled down I started looking around and found the EBPV stuck shut. I got it disconnected and open. Did this do any damage of any kind? Could it have damaged the trans in any way? With it open, it starts and runs ok. Thanks for any help.
Old Jun 13, 2006 | 07:09 PM
plowhand's Avatar
plowhand
Playing in the Dirt
It only restricts the exhaust gas flow to aid in engine warm up. It should not have caused any damage to anything. I have known several poeple that have driven several weeks with them stuck closed and complained of no power and a whistling sound. We just unplugged them and opened them.
Old Jun 13, 2006 | 07:35 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Depends on how hot it got and for how long.
Check the shaft play of the turbo and monitor the engine for excessive blow by or oil consumption. Chances are you'll be fine.
Does the 97 have an EGT gauge?
Old Jun 14, 2006 | 05:16 AM
trike1946's Avatar
trike1946
Thanks for the replies. It does not have a gauge, but I will have one on in a few days.
It seemed to run ok last night. I took it out for about an hour. It had it's normal power back, which is not great to start with. It's an E series. I will keep a check on the oil and blow by.
mtnsammy
Feb 26, 2014 11:17 AM
justinpoe
Jul 20, 2012 09:44 AM
BuckHammer
15
Feb 15, 2012 12:42 AM
Highridge
Aug 31, 2010 04:37 PM
true blue
Nov 22, 2006 06:26 PM
