NP435 Swap
Old Jun 13, 2006 | 02:59 PM
martimani85F250's Avatar
martimani85F250
NP435 Swap
I just recently bought a '72 250. Right now I also have a '85 250 with a NP435 that i would like to swap in the '72. The '72 has a 360 FE series engine. I was wondering about bellhousings. The 85 NP435 uses the windsor bellhousing-what bellhousing did the FE series engines use or is this gonna be a direct fit? Haven't pulled either trannys out yet so...
Old Jun 13, 2006 | 06:38 PM
banjopicker66's Avatar
banjopicker66
The Fe bellhousing is unique to FE engines; it won't fit anything else.
Look for one behind a 352, 360 or 390 in trucks '65 - '76.
Old Jun 13, 2006 | 07:31 PM
Ford_Six's Avatar
Ford_Six
That new of an NP435 has a different size input bearing housing, I'm not sure if it'll fit the older bellhousing properly. I think it changed in 74 or 75, you might want to ask in the transmission forum as to what year bell housing you can use with that tranny.
Old Jun 13, 2006 | 08:35 PM
idealtrucks's Avatar
idealtrucks
I just put an NP435 that came off of a 360 on my 240. Bolted right up. Or did you mean the bellhousing attaching to the motor?
martimani85F250
thanks fellas i will take it to the transmissions forum
