1978 - 1996 Big Bronco
1987 ford bronco
Old Jun 13, 2006 | 01:37 AM
bigbadhonu's Avatar
bigbadhonu
1987 ford bronco
Hi, I have a 1987 ford full size bronco with a 302, does anybody know if this year came with 2 fuel pumps( low pressure in tank and high pressure on the fram? Any help woud be really helpful,Aloha
Old Jun 13, 2006 | 06:00 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
See you on the boards. ….
Old Jun 13, 2006 | 06:26 AM
helirich's Avatar
helirich
I use to have an 88' and it was set up like that. Yours may be differnt because they changed a lot (in the body at least) in 88'. Now I have a 90' and it has only the high pressure in the tank. If its the same, your high presure is located on the frame just under the drivers foot.
Old Jun 13, 2006 | 11:46 AM
jem270's Avatar
jem270
I don't have my book with me but I think the 87 to 89 models have the low pressure and high pressure pumps.
1988 EB Bronco - 302 - AOD - 3.55 Lim Slip 8.8- Manual Hubs and Transfer Case - BFG 32/11.5 AT - 209,000 miles
Old Jun 20, 2006 | 12:08 AM
bigbadhonu's Avatar
bigbadhonu
Well I dropped the tank today and took out the intank fuel pump.The strainer looked fine and I then hooked up the pump to a 12 volt power source and it worked just fine. It wasnt that hard to take it out.now I will check the high pressure pump on the frame and hopefully thats the problem. any suggestions would be good...Aloha
Old Jun 20, 2006 | 06:24 PM
khadma's Avatar
khadma
Carpenter Local 745
where are you?
Are you on O'ahu?
What are the problems you are having with the fuel system? I remember having to check alot of parts on my 1988 F-150 w/ a 302. Does the truck not run at all?
I have to change the sending unit on my 1996 Bronco with a 351.
keep us posted.
khadma Wahiawa.
Old Jun 20, 2006 | 09:02 PM
greystreak92's Avatar
greystreak92
Yes, hi and low pressure pumps on the 87's. What exactly are the symptoms?
Old Jun 21, 2006 | 12:34 AM
bigbadhonu's Avatar
bigbadhonu
Howzit khadma, I live on the big island oh hawaii. The bronco started to act like it was running out of gas then it just died. When I turn the key I can hear it cycle and charges the fuel system. When I start it it will run for about a minute the start to sputter like its running out of gas, then it dies. It wont run until I turn the key a few times and starts right up then dies again. Today I pulled out the high pressure pump and tested it on a 12v power source on it ran perfect, so I put it back thinking that it might be the fuel pressure regulator.When I started I up it ran and just kept on going.Maybe it was a bad connection or something. Kind of afraid to take it on the road for fear of it dying again and having to have it towed home again.I ran it for about 10 min. around the yard and have no problems so far....Will keep you guys posted Aloha
Old Jun 21, 2006 | 11:01 PM
bigbadhonu's Avatar
bigbadhonu
1987 bronco
Well today I ran it up the road about 1/2 mile from my house and when I got home it started to act up again. It started to sputter again and then dies out and I and back to square one again
Old Jun 21, 2006 | 11:02 PM
bigbadhonu's Avatar
bigbadhonu
What do you guys think that I should try now?
Old Jun 21, 2006 | 11:11 PM
greystreak92
Check the FPR (fuel pressure regulator) for fuel inside the vacuum diaphram. Its about the only indication that the FPR is bad and its not necessarily 100% accurate. When was the filter last replaced? Has the inertia switch ever been tripped?
bigbadhonu's Avatar
bigbadhonu
By the way, the emisions light is on and has been on 3 weeks prior to having this problem.I dont have a reader and if I do what kind do I need, Aloha
Old Jun 22, 2006 | 12:14 AM
bigbadhonu's Avatar
bigbadhonu
Hello greystreak92, The filter was changed about 6 months ago and the inertia has never tripped before. How do I check if there is fuel in the diaphram?do I have to disconect in from the fuel line?Aloha
Old Jun 22, 2006 | 01:47 AM
khadma's Avatar
khadma
Carpenter Local 745
Are you sure that the low press. pump is okay? did you get a new one?
I know that was the main reason for my '88 to not run. I changed every part but that one at first, and the truck ran after that. I even replaced the reservoir.
The in tank pump is critical to get fuel to the hi press. pump.
Old Jun 22, 2006 | 02:25 AM
bigbadhonu's Avatar
bigbadhonu
Hey khadma, when iiiI took it out and hooked it up to a pwr source it ran and it was quiet so I didnt get a new one.Is the reservoir behind the hi pressure pump on the frame?
