Transmission pan bolt torque?
Old Jun 12, 2006 | 06:58 AM
Proud Veteran 87's Avatar
Proud Veteran 87
Anyone know how much (ft lbs.) on the tranny pan bolts on a 2004 Ranger.Thanks!
Old Jun 12, 2006 | 08:12 AM
stuart1's Avatar
stuart1
115 - 133 " lbs
12"lbs = 1'lb.
Old Jun 12, 2006 | 09:50 AM
jim henderson's Avatar
jim henderson
Watch that you are using inch pounds and have an inch pound wrench.
I don't know the torque for your tranny but the other guy appears to know.
One thing I have noticed on some trannies is that depending on the gasket material, sometimes the recommended torque is too much.
As you torque things down, wath the gasket. Make sure that the gasket is not being squeezed out from between the pan and tranny. A sure leak if this happens. YOu might have to torque to less than recommeded to prevent the gasket from squeezing out.
I usually like to use some gasket sealer on the gasket to hold it in place. It seems that some of the rubber and some of the cheaper cork gaskets will still slip while torquing so watch carefully.
If you are forced to torque to a lower reading than spec you might put a small dab of gasket sealer on the threads of the bolts to keep them from vibrating loose.
Good Luck,
Jim Henderson
Old Jun 12, 2006 | 10:32 AM
stuart1's Avatar
stuart1
Cienega32
Dec 12, 2016 11:26 PM
neilc88
Modular V10 (6.8l)
May 31, 2013 09:13 AM
bridge
6.7L Power Stroke Diesel
Nov 11, 2012 07:49 AM
caclark1992
Dec 4, 2011 11:18 AM
bronzo510
Jul 31, 2007 12:03 AM
