Volare Dropped Spindles??
Old Jun 11, 2006 | 10:12 PM
harley f150's Avatar
harley f150
Has any one used the Fatman dropped spindles for the Volare suspension. I am unable to get the front suspension low enough to match the back (axle flipped on top of the springs. I just wanted to know if they were worth the $500.
Thanks in advance
Doug
Old Jun 11, 2006 | 11:22 PM
sdetweil's Avatar
sdetweil
I have not, but am planning to..
Sam
Old Jun 12, 2006 | 12:45 AM
blitzkraig56's Avatar
blitzkraig56
I was a bit disappointed in them. For $500 I expected a no problem bolt in. But they do require some grinding which the included instructions tell you where. I think that's crap, but where else are you going to get em? Other than that they work good.
Craig
http://www.evil-wheels.com
Old Jun 12, 2006 | 06:10 AM
merc546's Avatar
merc546
Just got mine a couple of days ago. I can't install them till sometime next week. They can't be anymore work then the modified lower control arms that I got from No Limit which I am now replacing with the dropped spindles and stock control arms.
Chuck
Old Jun 21, 2006 | 05:27 PM
merc546's Avatar
merc546
Ok,
A friend and I just finished installing the fatman dropped spindles on my Volare front susp.
In my case it was a little more involved then just a simple bolt in.
Had to grind the caliper mounting bracket like they said but then we had to grind about 3/32 off of the outside surface next to the rotor so the rotor would turn.
Then we had to remove approx 1/4 off of the length of there spindle to steering arm bolts it was hitting the torsion bar mounts,preventing a full lock to lock turn.
Finally the brake hose had to be moved to miss the ball joint stud.
They only cost $505.00 plus shipping. Why would I think they would bolt in with no problems?
Chuck
Old Jun 21, 2006 | 06:13 PM
53fatfndr's Avatar
53fatfndr
There is no such thing as a bolt on
Old Jun 21, 2006 | 09:42 PM
sdetweil's Avatar
sdetweil
Originally Posted by merc546
Ok,
Chuck
and after all that, dd you get the drop and arm movement increase that you had expected?
my running board front edge is 4 inches off the ground at ride height, with 15in wheels.. will be going to 17's or 18's in the front.. so that will raise me up 1-1.5 inches. plus tire height.. so I want the 2 inches back.
Sam
Old Jun 22, 2006 | 06:04 AM
merc546's Avatar
merc546
I am still setting the ride height. It did drop to much when I first checked I was also in the 4 inch range but we couldn't tell if the lower arm was parallel to ground.
The big deal at the moment is trying to get it somewhat level from side to side
Maybe it will have some suspension travel this time while remaining low. I have P215/70R15 on the front.
Chuck
Old Jun 22, 2006 | 06:37 PM
merc546's Avatar
merc546
Took it to the alignment shop this afternoon. The running boards are now setting 5 1/2 inches from the ground at the front corner. Seems to have enough travel now.
Did have my usual fun at the shop. The mechanic said truck was done but the driveshaft must be hitting something. I thought perhaps it was rubbing the muffler (new driveshaft is 1 inch larger dia) anyway I started the truck backed it up stopped it, got the mechanic and ask him to look at the rotors.
As my luck seems to go when he moved the upper arm outboard it tipped the rotor into the lower control arm and it was rubbing (more like grinding) the rotor (you would think he would have noticed that before he scored my rotors).
Showed him how I wanted it fixed, he did that and then charged me a extra $20.00. Nice !
It would have been a good idea for whom ever designed these spindles to think about mfg tolerances. Anyway truck now rides good as well as looking good (new wide whites with old's style full hubcaps)
Chuck
