1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
left rear brake getting hot
Old 06-11-2006 | 02:35 PM
95frd's Avatar
95frd
i drove into town and came home and noticed my left rear brake was hot. I dont know if i need to pull the caliper off or what.
its a 02 f-350 SRW
Old 06-11-2006 | 07:28 PM
Rongold's Avatar
Rongold
Hot
Did you check the other side to make sure that it is hotter than that one ??? Did you accidently drive with the E-brake on ??? If neither of the above applies, check the sliding pins on the affected caliper. They have a habit of siezing up on super duties. If they are siezed up, try and pull them out, (could be quite hard), wire wheel them, and reinstall using some hi-temp synthetic caliper slide grease. If they are free, try compressing the pistons in the caliper. I've never seen one sieze, but anything is possible.
RON
Old 06-11-2006 | 11:20 PM
Cuda444's Avatar
Cuda444
I had a caliper seize up on one of my back wheels. Definitely check the slide pins first. When my caliper went even a c-clamp wouldn't push the piston back in. If you have to replace it, you may as well replace the other side.
Let us know how it turns out.
Tom
parkers5150
01-27-2014 10:19 PM
70T351W
09-24-2013 03:01 AM
hd883chopper
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
22
09-26-2011 03:34 PM
superpelly
1997-2006 Expedition & Navigator
05-03-2007 06:53 PM
revupar
Electrical Systems/Wiring
10-07-2003 07:30 PM
Quick Reply: left rear brake getting hot
