Breaks are sticking
Old Sep 23, 2013 | 07:30 PM
70T351W's Avatar
70T351W
Breaks are sticking
This is really not a ford but it has the 7.3 in it. The front left brake was sticking because it only had one bolt in the caliper. (Very scary I know) I replaced the bearings, races, seal, rotor, caliper and pads with 2 new caliper bolts. Coming home today the breaks got really hot after break checking some dip****. Pulled the tire off and the hub spun fine then I pressed the brake, released it and then it wouldn't. what the heck. no air breaks. the truck is a international 4700, 2001 model.
Old Sep 23, 2013 | 09:25 PM
ReBilld's Avatar
ReBilld
I've seen the flexible rubber brake lines come apart inside and only let the fluid flow through one way. Acts like a check valve. Sounds like that's the only thing you haven't replaced, might be worth a try.
Old Sep 23, 2013 | 09:36 PM
JWC 3's Avatar
JWC 3
I see lots of problems with juice brakes on this class of truck . Hoses often ! . Calipers and slides also . If hot enough to smoke , replace the pads , hoses and calipers ( all ! both sides) on the front axle . Be ready to do the rears soon .
Old Sep 23, 2013 | 09:51 PM
madMatador78's Avatar
madMatador78
X2 on what Bill and JWC said, I have seen this in my shop as well. Only way you would know is to change them rubbers out.
Old Sep 24, 2013 | 03:01 AM
tjc transport's Avatar
tjc transport
i ain't rite
normally you will not be able to turn the rotor with the caliper on and loaded with the wheel off.
but if it is dragging, the caliper may be bad, or the hose could be collapsed internally.
Swaybar1
Nov 3, 2019 09:29 AM
WolfCreek540
Apr 10, 2017 12:56 AM
BriWas
13
May 24, 2012 05:14 PM
MuddyWaters
Oct 2, 2010 02:24 PM
77300i6
Sep 27, 2004 06:18 AM
