C-4 leak
Old Jun 10, 2006 | 02:35 PM
Major1095's Avatar
Major1095
C-4 leak
I installed a c-4 in my 66 F-100 and over all it is a good setup. Howwever, it is starting to leak very slight around the rod that the shift rod hooks to. Is that a big thing to replace or do you need to take it to a transmission shop?
Old Jun 11, 2006 | 09:42 PM
cujo8's Avatar
cujo8
Where exactly is the leak? Is the leak behind the bigger (shift lever) or near the end where the kick-down lever is attached w/ a nut and lock washer? If the leak is in the end you may be able to fix it, since it is just a O-ring that sits under the the kick-down lever/lockwasher/nut that seals the kick down lever shaft. If the leak is around behind the shift lever than the transmission needs to be tore apart to get at it, since this lever is bolted on from inside the transmission. I'm in the middle of rebuilding my C4 tranny for my 77 F150 right now and I was just looking at these seals 10 minutes ago! Good luck.
Jim
fiveofsevin
WTB - Parts & other
Nov 18, 2013 02:34 AM
f350 goatee
13
Aug 15, 2007 11:07 PM
jenkinsj
Jul 22, 2005 07:25 AM
GWB
Jan 9, 2000 02:50 PM
