351M -- engine pulled + Paint Question
Old Jun 9, 2006 | 01:38 PM
olblue76's Avatar
olblue76
I have a F250 4x4 with a 351M that has 64,000 original miles. The engine is bone stock & is running great. I just adjust the carb every so often for the idle.
I'm looking to have the engine pulled, some minor performance done; such as 4 bbl, headers, etc.. and the engine bay repainted. The truck has just been repainted back to factory specs. Truck is used to hunt/fish only. Non DD.
I'd like the engine bay to be back to par as well.
1. Is it worth pulling an engine with so few miles to do some minor mods, check for any unseen problems & paint the bay??? I'm not looking to max out HP, just a little bit extra.
2. Should I have someone try to paint the bay around the engine & not pull it??? My guess is a big NO.
3) If I have the engine pulled, how much should I expect to pay for the engine being pulled(ball park) ?? Am I looking at $$$$.
Thanks for any advice.
Old Jun 9, 2006 | 07:18 PM
sparky69's Avatar
sparky69
none of the performance mods you listed require removal of the engine. it may be easier to do the painting with the engine removed, however. depends upon how nice ya want it to look. if ya take the time to pull the engine ya should check it over real good. this may lead to lots of additional time and $$$. you should be able to rent an engine puller for a reasonable price if you have the space and tools to do the job.
Old Jun 10, 2006 | 12:21 AM
olblue76's Avatar
olblue76
I guess what I'm looking to do is the performance mods & did not know if it was worth the $$$ to pull the engine to make the engine & bay shine back to factory glory. I'm thinking a great tuned, shiny engine looks a little bit out of step with a deteriorating engine bay.
Guess I'm going a little overboard... I'll just do the mods and worry about the "look" later.
Old Jun 10, 2006 | 11:54 PM
roger dowty's Avatar
roger dowty
there ya go...I'd never pull a motor unless I had to and once it's out it gets everything- bearings and the mods that make the most sence- like pistons or heads and...roller cam!!! So i have to either save up $$ or buy a block and do it as i can before pulling.
Haydendh
Oct 3, 2014 01:11 PM
honda_guy4
Jan 28, 2014 03:10 PM
71 Sport Custom
Nov 16, 2010 10:29 PM
muscletruck7379
Paint & Bodywork
Sep 15, 2009 12:19 AM
1979camperspecial
24
May 17, 2009 10:36 AM
