Defective oxygen sensor in 97 Explorer
Old Jun 8, 2006 | 08:45 PM
mark b's Avatar
mark b
The check engine light was coming on periodically at highway speeds in my 1997 Explorer (4.0L V6 SOHC, 91,000 miles). I hooked up an OBD-II code reader and got a P0153 code. The software says I have a defective oxygen sensor (stuck lean) on Bank 2, sensor 1 (upstream). Am I correct in thinking that Bank 2 is on the opposite side from cylinder No. 1 and the upstream sensor is the one closest to the exhaust manifold?
Mark B.
Old Jun 9, 2006 | 07:47 AM
ajguzik's Avatar
ajguzik
You are correct. Bank 1 is on the passenger side, Bank 2 driver's side. The sensor is in the Bank 2 exhaust manifold, and should be accessible from under the Exp.
Old Apr 22, 2017 | 07:10 AM
zebra99's Avatar
zebra99
trouble code p0420
I have a 1997 explorer with 4 liter SOHC V6 with 140k miles on it.
Problem starts out as a pending code P0420 then after a time lights the service engine light. Erasing the code just causes the problem to repeat. The code indicates a weak catalytic converter. Could the real problem be a weak or defective oxygen sensor?
Old Apr 22, 2017 | 03:44 PM
85e150's Avatar
85e150
Welcome to FTE.
I can't tell you one way or the other, but I do know that intake leaks will cause a "lean" code and are many times thought to be bad sensors.
The intake O-rings are trouble. Cracks are not unheard of either.
Running it lean or with a miss will eventually kill the cat, so IMO it's worth running down the intake and any lean codes when you get a code like yours.
whodatsaints
16
Jan 14, 2024 03:32 PM
ANGTFT14
Jan 7, 2018 06:34 PM
ten.mile
1983 - 2012 Ranger & B-Series
Oct 4, 2017 07:24 AM
6.9idiatsturbo
Modular V10 (6.8l)
Mar 5, 2017 09:59 AM
Panama1
1997 - 2003 F150
Jan 5, 2017 10:46 PM
