02 sensor problem (bank 2 sensor 1) - Ford Truck Enthusiasts Forums
Old 03-04-2011, 12:57 PM
whodatsaints
whodatsaints is offline
whodatsaints is starting off with a positive reputation.
Talking 02 sensor problem (bank 2 sensor 1)
Hello everyone
I had the guy at AutoZone scan my car and this is what the printout said:
Fuel trim bank two condition
The ECM has detected a rich or lean air/fuel ratio condition on engine bank 2
If bank one and two are set together suspect a fuel pressure condition or MAF sensor fault
- Failed H02S21 (Heated 02 sensor - Bank 2 Sensor 1)
-Ignition misfire condition
-Engine mechanical condition
Definition: Lack of heated oxygen sensor - Bank 2 Sensor 1 H02S21 switch sensor indicates lean
Explanation: ECM tried to correct for a lean condition - ECM made rich correction but was unable to bring within specifications
Probable Cause: Failed H02S21 Bank 2 Sensor 1
Open or Short circuit condition
Failed fuel pump or blocked fuel filter
MAF sensor failure
Vacuum Leak
Anyway can anyone tell me if I am correct in assume all of these problems stem from the Bank 2 Sensor 1 02 sensor? And if so could you tell me if that is passenger side/driver side and upstream/downstream? I really appreciate any advice as I would like to handle this on my own.
2006 Ford Explorer XLS 6 cyl
Old 03-04-2011, 01:50 PM
WillFargo
WillFargo is offline
WillFargo is starting off with a positive reputation.
Does the 06 v6 have dual exhaust? if its dual its on the drivers side, before the cat converter, which is your upstream
Old 03-04-2011, 06:29 PM
aquanaut20's Avatar
aquanaut20
aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
It has no bearing on whether the vehicle has single or dual exhaust. Each bank of cylinders has an O2, B2S1 is the 1st sensor after the exhaust manifold (pre CAT) on bank 2. In your case that would be the driver side. The designation of the O2 post CAT would be BxS2.
The S1 O2 are used by the PCM to adjust fuel/air ratio, the S2 are only to monitor the CAT efficiency..
Do not assume that you have an O2 issue, use a proper SCAN tool (computer) and read the live data, MAF, O2 and fuel trim. Philip
Old 03-04-2011, 08:38 PM
shorod's Avatar
shorod
shorod is online now
shorod has a great reputation on FTE.shorod has a great reputation on FTE.shorod has a great reputation on FTE.shorod has a great reputation on FTE.
I agree with Aquanaut. This probably is not an oxygen sensor issue but rather a vacuum leak.
-Rod
Old 12-06-2017, 05:31 PM
Tdagg
Tdagg is offline
Tdagg is starting off with a positive reputation.
Where is bank 2 sensor 1 on a 02 Ford Explorer xls
Old 12-06-2017, 08:03 PM
shorod's Avatar
shorod
Welcome to the forum!
Did you read post number 3 above? I think Aquanaut did a pretty good job of explaining it. Do you have a more specific question?
-Rod
Old 02-22-2018, 04:44 PM
RandomMechanic
RandomMechanic is offline
RandomMechanic is starting off with a positive reputation.
live data!! What am I looking for?
I have a 96 explorer awd v8. I'm pulling the same codes and I know enough to know that this is not the o2 sensors. I've got a proper scan tool to read live data but I have no idea what I'm looking for to narrow this down. I've collected a laundry list of possibilities from maf sensor, to vacuum leak, to manifold gasket. What am I looking for to narrow this down?
now that I write it, those are all pressure related and would probably read the same in live data anyway... Mother fu....
any help is greatly appreciated!
Old 02-22-2018, 09:24 PM
shorod's Avatar
shorod
Out of curiosity, what codes are you pulling?
Are you familiar with what the expected O2 sensor voltages should look like for sensor 1 versus sensor 2? You're basically wanting to monitor the switching frequency of sensor 1 and when it reads lean versus rich relative to the readings of the short term fuel trim compared with the MAF flow readings.
-Rod
Old 02-22-2018, 11:40 PM
RandomMechanic
Codes... 8 of them...
All upstream o2 sensors here they are:
p0133 o2 circuit slow response (b1s1)
p0153 o2 circuit slow response (b2s1)
p0155 o2 heater circuit (b2s1)
p1151 lack of ho2s21 switches sensor indicates lean
p0133(repeat don't know why?) b1s1
p0153(again) b2s1
p0155(again) b2s1
p1151(again) ho2s21
the bank 1 sensor is brand new, I'm going to replace the bank 2 sensor now and run the truck around a bit (had to custom make a tool for the angle ended up easier than taking the console apart)... I'll report in the morning.
I want to jump to a computer fault, but after talking to my father and writing to you I'm starting to rethink my angle... It's got a minor exhaust leak I believe, but also a long hold to start (meaning I have to crank it for about 3 seconds). I had a v6 that fired much quicker than this. She runs like a dream when shes going..
Old 02-23-2018, 07:04 AM
shorod's Avatar
shorod
The repeat of codes is probably due to one set being "active" and the other being "stored" or "historical", meaning it's been throwing these codes for awhile and the last time you drove the vehicle they were still active.
With the range of codes you list, I'd be focusing my efforts on looking for a vacuum leak and repairing that exhaust leak. The P0133 and P0153 could both either be caused by a vacuum leak or an exhaust leak.
The P0155 would most likely be due to either a bad bank 2 sensor 1 sensor, a wiring issue to the sensor (check the fuses), or possibly a PCM issue. I wouldn't jump to the PCM yet though.
The P1151 has several possible causes, but could again be due to a vacuum leak (among several other things - fuel pressure, oil dipstick not seated, PCV valve issue, plugged air filter, etc) and could also contribute to the P0155 code.
-Rod
Old 02-23-2018, 03:48 PM
RandomMechanic
Thank you!
I seem to want to always go worst case scenario, but I should listen to my dad more too. Thanks Rod, I appreciate the knowledge. I haven't owned fords long (truth be told I never would have bought it except it fell in my lap at too good of a price). I've got other makes funny little problems down I hope it won't take long to get this explorer down.
Sgt93
6.7L Power Stroke Diesel
02-05-2018 12:48 AM
buddymanzpop
Modular V10 (6.8l)
01-19-2018 06:51 PM
kf7dwc
1997 - 2003 F150
12-28-2017 02:31 PM
Whitey Ford
Ranger & B-Series
04-27-2017 06:43 AM
Quick Reply: 02 sensor problem (bank 2 sensor 1)
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
