clearance light install?
Old Jun 8, 2006 | 08:30 PM
sean23johnson's Avatar
sean23johnson
i bought a set of clearance for my truck (ford parts with ford harness) and wanted to know if anyone out there has installed these on their truck? i am a little nervious about drilling holes in the roof of my truck so if anyone out there has any advise i would love to hear about it. also where does the wiring harness connect to? thanks.
Old Jun 8, 2006 | 08:37 PM
yellow401's Avatar
yellow401
I installed them on my truck, see gallery, and had to go to the dealership and physically take exact measurements off a truck that had lights from the factory, as I wanted mine to be exact. I had no templet, so I had to make mine with my measurements, and I also ran my own wiring to tap into the running lights on the light ****. Measure 10 times and drill only once!! Lay the lights on the roof untill you know they are right and trace around them. You'll do fine!
Old Jun 8, 2006 | 10:09 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
That's exactly how I did it too.
The factory harness connects behind the passenger side kick panel down in the footwell. If you have an overhead console the harness will be different from the one without. I bought the harness without the overhead console just to get the correct connectors for the lights and made my own harness that ties into the dash switch.
Oh...and that nervousness you are feeling about drillng 15 holes into your perfectly good roof isn't going to go away until you're done. Take it slow and steady.
Old Jun 9, 2006 | 02:34 AM
ryaneverk2's Avatar
ryaneverk2
Hahaha, yes I can imagine that the hole drilling part is the hardest part. You should've seen me before I made the first cut with the grinder on my perfectly good bumpers for the backup lights. I'm sitting there with a grinder buzzing an inch from the bumper... waiting... steady hand... deeeeep breath, and EERRRREEEEEEECCCHHHH perfect bumper gets scorched. No stopping at that point... the point of no return.
PS - if you do a search on: +clearance +lights or "clearance lights" and narrow it to the Superduty section, you'll find quite a few posts on the very subject with lots of good info.
Old Jun 9, 2006 | 06:09 AM
Kwikkordead's Avatar
Kwikkordead
Yes, measure twice, thrice, however many times necessary to get the proper placement and it will go fine.
Also remember that if you still get a woopsie it's a simple task to fill it back in with a wire feed welder and paint. Little job like that at a bodyshop wouldn't be much at all.
Old Jun 9, 2006 | 09:43 AM
fordboy2's Avatar
fordboy2
did mine this morning wasent too bad kinda nerve racking, but looks good as long as they dont leak now Im stylin!
Old Jun 9, 2006 | 11:08 AM
crosbo's Avatar
crosbo
Fordboy, how long did it take to perform the install?
Old Jun 9, 2006 | 08:16 PM
JRB's Avatar
JRB
lights
http://www.emotoman.com/f250/indexf250.html
This site has good pics and instructions. Hardest part is drilling the first hole !
Mine did not have the wiring harnnes, I tapped into the power wire for the highlights just behind the switch.
good luck
jrb
02/cc/psd
Old Jun 10, 2006 | 01:48 AM
Go Aweigh2452's Avatar
Go Aweigh2452
Just make sure you seal around the hoels you drill with silicon or some kind of epoxy paint to slow down any possibility of rust or water penetration.
BTW, I hooked mine up to the day time running lights (Canadian built F350).
Old Jun 12, 2006 | 12:31 PM
fordboy2's Avatar
fordboy2
it took maybe two hours, remmember measure and remeasure.
brianedward69
Jan 22, 2015 04:12 PM
jh225
Aug 9, 2012 01:51 PM
Bill Nolan
2009 - 2014 F150
Jun 22, 2011 04:46 PM
dfs
Apr 4, 2011 10:33 PM
koboss1
6.4L Power Stroke Diesel
28
Dec 22, 2009 10:20 AM
