I should change radious-arm & axle-pivot bushings when I change to disc brakes. Are these new Polyurethane Bushings any good? I'm looking at the "Energy Suspension" ones that LMC sells. I've heard that they tend to squeak, and give a rough ride, but this is the oposite of eveything Energy suspension claims. Mabey these guys are using the cheepo brand of poly bushings, instead of the name brand. Anybody got this brand of bushings?
P.S. The poly bushings are less expensive than the rubber in LMC's catalog, so I'm hopping I get good reports.
I used the kit from performancesuspension.com which came with Energy Suspension bushings when I did my disc brakes- no problems. Also replaced the steering linkage and front springs while I was at it.
