New Intake/Check Engine light
Old 06-08-2006, 11:47 AM
JHag04FX4's Avatar
JHag04FX4
JHag04FX4 is offline
I just installed a new intake (CGS intake sysytem) on my 2004 FX4 5.4L and after running it for about two days the check engine light came on.. I took the intake off and put the stock one back on because i am getting my cam phasers replaced at the dealership and i just didnt want to have and issues witht he aftermarket intake.. they ran it and the computer program (light was still on but with stock intake) and the program found no codes and the light jsut turned off... when i get the truck back i plan and putting the intake back on along with a trottle body spacer i have just recieved. what can be done to the the heck engine light from coming on if indeed my intake did cause it? will and edge evo fix this?
Old 06-08-2006, 11:50 AM
Cavtrooper06's Avatar
Cavtrooper06
Cavtrooper06 is offline
When the check engine light comes back on use the edge to determine the DTC (troubleshoot code), mass air flow sensor maybe?
Old 06-08-2006, 02:41 PM
derek4343's Avatar
derek4343
derek4343 is offline
the cai tends to run lean.yes the edge will fix it. i had the same problem. nn
Old 06-08-2006, 07:25 PM
captchas's Avatar
captchas
captchas is offline
Guest
spacer
send the spacer back man all it does is take cash out of your pocket. they are the most worth less thing i ever purchased
Old 06-09-2006, 03:00 AM
one5150fisher's Avatar
one5150fisher
one5150fisher is offline
I had the same problems with the ariraid at times I checked the codes and it was a lean condition at one of the cats. Make sure all the seals are tight and you have to unhook the battery so the computer resets itself. It should adjust to the increased airflow. Hope it helps.
Boats12
1999 to 2016 Super Duty
11-17-2019 04:49 PM
302flareside1992
03-09-2010 06:18 PM
cougar73
3.8 & 4.2L V6
10-06-2008 10:00 AM
1COOKIEMON
09-23-2007 06:37 AM
02FX4Dude
15
07-06-2005 11:27 AM
Quick Reply: New Intake/Check Engine light
