460 SWAP
Old Dec 17, 2001 | 02:18 PM
68FORD's Avatar
68FORD
460 SWAP
I HAVE A 68 F-100 SWB W/70 302 & C-6. I FOUND A GOOD DEAL ON A 76 460.
HOW DIFFICULT OF A SWAP IS THIS? I KNOW I AM GOING TO HAVE TO CHANGE SOMETHING ON THE TRANSMISSION, BUT I'M NOT SURE WHAT? I 'VE GOT A CALL INTO A TRANSMISSION SHOP THAT IS GOING TO ANSWER SOME QUESTIONS AS WELL.
WILL I NEED A DIFFERENT TORQUE CONVERTER? WHAT MOTOR MOUNTS CAN I USE? I KNOW I HAVE PLENTY OF ROOM BUT I JUST WANT TO KNOW WHAT ELSE I AM GOING TO ENCOUNTER WHEN I DO THIS.
THANKS IN ADVANCE FOR ANY INFO.
Old Dec 17, 2001 | 05:03 PM
ford fanatic's Avatar
ford fanatic
460 SWAP
I went in the opposite direction earlier this year. Your transmission will not work the bellhousing on a 460 is much bigger than a 302.
You will also have to change the engine towers get some from a junk yard. Find a truck that had a big block those will work
Old Dec 17, 2001 | 05:53 PM
Mil1ion's Avatar
Mil1ion
460 SWAP
Please Don't post in ALL CAPS.
First, it is considered Yelling and it IS Very difficult for some people to read.
Thank you.
Dennis
It's Almost Time Everyone.
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=314&.jpg
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old Dec 20, 2001 | 07:31 PM
mk's Avatar
mk
460 SWAP
In addition to finding 460 engine mounts from a 73-79 and a 460 c6 transmission, you will have to have your driveshaft modified for length. Maybe someone on the list who has done this will provide some measurements for you. The wheelbase on the 73-79's is two inches longer so you can't use the original shaft from one of these.
Old Dec 22, 2001 | 12:48 AM
mav's Avatar
mav
460 SWAP
What about headers for this swap? Are there any available? I've also got a 68 F100, and I plan on doing the 460 swap someday soon, but I don't really want to choke down my 501 inch big block with exhaust manifolds.
Old Dec 22, 2001 | 04:55 PM
rugger's Avatar
rugger
460 SWAP
Get ahold of L&L and they can help with the headers, as well as other componets. Your drive shaft will need to be shorten but let the drive line shop take care of the details call them first tell then what your doing and they will tell you where to take your measurement from. I've done two in a bronco (79) and have come out sweet but I had to deal with 4 wheel drive as well You will enjoy the horse's, should be fun for yea. If you run into anything else my e-mail is wevans@tmcc.edu
Old Dec 25, 2001 | 09:02 PM
gkelso's Avatar
gkelso
460 SWAP
I took a 302 and C4 out of my 68 2 years ago and put in a mid seventies Lincoln 460 with a C6. It was a pretty easy swap. I got the motor mounts from PAW in their motor mount swap section and used Hedman headers. Had to get the driveshaft shortend which cost about $100 including new u-joints. I used transmission mounts from a Lincoln. The 460/C6 combo has a different belhousing than that on my 302. So I used the one that came with the 460. Used a B$M shifter. I rebuilt the 460 while I was at it. Runs great.
jerry
Old Dec 25, 2001 | 11:51 PM
orangeford's Avatar
orangeford
460 SWAP
