Offroad & 4x4
16" wheels with 315's...
Old Jun 7, 2006 | 08:39 PM
drj777's Avatar
drj777
Question 16" wheels with 315's...
any suggestions on gears...3.73...4.10 or 4.56???
drj
Old Jun 7, 2006 | 08:49 PM
JeremyH's Avatar
JeremyH
Stuff like this will depend on a lot of things....transmission, engine, on or offroad truck, etc.
You need to give more details.
Old Jun 7, 2006 | 09:12 PM
MBBFord's Avatar
MBBFord
Basically with stock engine, normal driving conditions, alittle towing, daily driver,
4.10s would be good to have, but for your exact case you'd need to give the info JeremyH suggested. What do you use it for?
Old Jun 7, 2006 | 09:45 PM
fishmanndotcom's Avatar
fishmanndotcom
i run that exact setup with my stroker and 4.10 gears and i have been very pleased. i run a lot of highway going back and forth from work in atlanta and i i have saved a lot of cash in fuel b/c i am not hitting near as high of RPM's as i was with the stock shoes.
the only time i feel a difference is when i am hauling a trailer in the hills, like around tellico in the mountains and even around grayrock there are a couple of real nasty hills that i can't hit any higher than 3rd gear.
its a great compromise
-cutts-
Old Jun 7, 2006 | 10:49 PM
drj777's Avatar
drj777
Talking
sorry - i always assume everyone can see the sig...but mine is hidden.(because i dont have the 'pay' account)
shes an '03 5.4 150 4x4 XLT supercrew with the 9.75 rear end...and of course the 16" 315s i mentioned earlier...
drj
Old Jun 7, 2006 | 10:51 PM
fishmanndotcom
you can see everyones sig if you hold your mouse cursor over the word "signature" at the top right of every post you make
-cutts-
Old Jun 8, 2006 | 06:12 AM
JeremyH's Avatar
JeremyH
Yep, and I always forget to look. Duh....
Old Jun 8, 2006 | 09:45 PM
drj777's Avatar
drj777
Thumbs up
so it sounds like 4.10's will be just fine...
still good for the highway...
better for everything else...
thanks!!
drj
Old Jun 8, 2006 | 10:32 PM
Customz's Avatar
Customz
That tire is ~10% larger than stock so gear 10% lower than stock will get you back where you started. I always favor lower than stock to save transmissions and for the extra power. Besides fueling and economy is more load dependent than rpm dependent on FI vehicles so mileage shouldn't suffer. The mechanical advantage of the lower gears requires less fuel per rpm (to a point).
Old Jun 8, 2006 | 10:46 PM
drj777's Avatar
drj777
Thumbs up
cool...thats good to know...
thanks for the info!!
drj
drj777
Offroad & 4x4
Jul 18, 2007 05:28 AM
drj777
Appearance & Dress-Up
Jun 11, 2007 04:10 PM
drj777
1997 - 2003 F150
17
Apr 5, 2007 10:40 PM
drj777
1997 - 2003 F150
Mar 24, 2007 03:29 AM
drj777
Offroad & 4x4
Nov 2, 2006 05:41 PM
