new member ..need help already??
Old Jun 7, 2006 | 03:47 PM
rockhi's Avatar
rockhi
Hello everyone . I just found the site while searching for answer to my problem. I hate to start off with questions, but I really could use some help..
I have 2003 7.3 that has been acting strangely last 60 days. It kind of misses or for lack of better words..like someone cuts of ign. for split second & scares the hell out of you..I finally had the check engine light come on today & I checked the code & it is P0344. I beleive that is camshaft sensor isn't it? Should I just go ahead & replace it?
I found the thread on here on how to install new one..sounds simple enough, but I do have a question on install? You don't have to worry about positioning the new sensor in any way like I used to have to do with my old Mustangs? Just bolt in and done?
Thanks for any & all help & again glad to find your guys & gals
Jeff
Old Jun 7, 2006 | 04:14 PM
ILBCNUL8R's Avatar
ILBCNUL8R
From the service manual:
P0344 - CMP - Camshaft position sensor ckt. intermittent
Causes: Harness routing, charging ckt., sensor, int. ckt., improper gap
Part numbers and sources are indicated in the following link, which will also assist you in the replacement process:
http://www.forgotton.net/mods/cpsframe.html
If you can wait a couple of days for delivery, the cheapest source for a new, factory-wrapped, CPS will be from e-bay. Somewhere around $50-$60 if you exercise Buy-It-Now.
Old Jun 7, 2006 | 05:09 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Welcome to Ford Truck Enthusiasts rockhi and ILBCNUL8R.
rockhi. You will not need shims, special placement or anything else. Pull the old one out and put the new back in the same place.
Old Jun 7, 2006 | 05:20 PM
t.j.g.'s Avatar
t.j.g.
i agree with cookie very easy
Old Jun 7, 2006 | 05:35 PM
roaky81's Avatar
roaky81
You may want to save the old one. Keep it (and the tools needed to replace it) in the truck for an emergency. Sounds like it'll work to get you home.
Old Jun 7, 2006 | 05:40 PM
GarrettShields's Avatar
GarrettShields
We offer the Black CPS & the Blue CPS
Like stated above, simple to install.
Old Jun 8, 2006 | 07:58 AM
Medic 66's Avatar
Medic 66
I agree....old out new in....
And EBAY is your best bet on an OEM ford packaged new one. I go tmine with shipping for 55.00
Old Jun 8, 2006 | 12:38 PM
F3504ME's Avatar
F3504ME
Black vs Blue CPS.
What is the diff??
Old Jun 8, 2006 | 12:58 PM
roaky81's Avatar
roaky81
I think the black is the Ford replacement and the blue is the International replacement. Do a search for "blue cps" and see the different opinions on both.
Old Jun 8, 2006 | 01:00 PM
F3504ME's Avatar
F3504ME
Great..
Thanks....
I assume the Blue IH unit is better....
I wonder why both Ford and IH make one and Ford does not just source them from IH??
Old Jun 8, 2006 | 02:07 PM
piotrsko's Avatar
piotrsko
my undesstanding is that IH sources them from ford since some of them come in ford packaging.
Old Jun 8, 2006 | 02:12 PM
Medic 66's Avatar
Medic 66
Originally Posted by F3504ME
Black vs Blue CPS.
What is the diff??
Black is original replacement. Blue is for the International DT466 I think.
Blue sees better MPG's and higher EGT's during towing I beleive also.
Old Jun 8, 2006 | 02:23 PM
NChornet's Avatar
NChornet
The above poster is right the blue is for a different engine and some claim when used in our engine that they gain 5 mpg, 25 psi of boost, 75 ftlbs of torque, and shaves 1.2 sec off the 1/4 mile.
