New 400 Piston, Need Feed-back
Old Jun 25, 2006 | 09:39 PM
danlee's Avatar
danlee
Originally Posted by danlee
I think that piston works well for stock open chamber heads on gasoline, and for closed chamber heads on E85.
I think that Bill Beyer once posted a link to a graph of Octane rating vs dynamic compression ratio. If I could find that graph, I could determine the maximum DCR for E85, and the static compression ratio to achieve this with a moderate cam.
Here is a link to the Popular Hotrodding article on Octane rating vs dynamic CR. based on this curve, you can run 10:1 Dynamic CR with 105 Octane E85.
http://www.popularhotrodding.com/tec...eze/index.html
Old Jul 31, 2006 | 09:26 AM
danlee's Avatar
danlee
If that link doesn't work, try this.
Old Jul 31, 2006 | 07:35 PM
battered_bronco's Avatar
battered_bronco
well timmie people seem to be digging the "9:1" badgers but why?
price
easy fit ... the right freakin pin size
it will run on pump gas
if you show them a stockish dieting 400 with the zero deck(maybe -0.010) that burns regular on stock/rv/summit/255DEH cam ya know nothing nuts just the way ford should of if the gas was right back in the day with a bit of power
long story short 9-9.5:1 zero deck -0.010" just make sure you dont screw the buyers that have closed chamber heads by cutting into the quench area
just 1 po-as opinion
ps option 1?? why would you consider making the same mistake as ford??? again
Old Aug 1, 2006 | 01:05 AM
roger dowty's Avatar
roger dowty
price
...option one was simply duplicating Badger but getting a constant supply- as i understand it. I had a set of badger sell for nigh on $200.00 due to shortage.
Its done and i missed it but TMI now also stocks the right piston for stock- open chamber heads. He has had the KB's for closed chamber head already so I'm thinking and hoping he made this one specifically for the open chamber. If your going closed chamber you might as well go for the specific piston.
Now I see a rebuild kit coming from tmi that will match anything you could possibly want out of a 400.
Old Aug 3, 2006 | 10:07 PM
battered_bronco
roger wouldn't a zero deck 9~9.5:1 w/open chambers still help or eliminate the dang pinging weve been dealing with for 35 years using a dish rather than just lowering the piston deeper in
pushing more of the hot exhuast out pulling nice cool A/F in
Old Aug 4, 2006 | 01:41 AM
roger dowty
True, if done right a zero deck will increase quench. But the flattop still creates 9:1 and is close to what Ford made when they designed the engine- then they left it in the hole and dished it which dropped a point or so off CR.
The flattop is not the mistake ford made- most will agree that the original 400 ('71) was a kickin motor and it allows for decking the block id needed or wanted. The original badger flattop was made for propane conversion but has been used to rectify ford's error of killing the compression.
I would not disagree that zero-deck pistons dished properly for open chamber heads and 9:1 compression is the best option most of the time. But the flattop 9:1 was not a mistake- dishing it and leaving it in the hole was. Also...9:1 is critical for using the 255 cam which many use. I don't think you can get enough quench to reliably and consistently run pump 87 with 9.5:1 and that cam- the dcr is too high (from what I have read and heard) You'd be knocking on close to 8.4:1 dynamic compression. Thats borderline for 92 from what I understand.
Folks are really going to have to be careful with these new zero deck pistons too. theyd best do their research or have someone who knows what they are doing build their motor. You have some leeway with flattops in the hole. all of this is imo.
Old Aug 4, 2006 | 01:46 AM
roger dowty
also the amout of exhaust pushed out depends on the volume above the piston on tdc which is the same if you are running 9:1 with both type of pistons...right? one is in the hole the other is dished ...the CR and thus the volume is the same.
Old Aug 4, 2006 | 08:42 AM
TMI's Avatar
TMI
FYI,
All of our pistons are a zero deck height piston. The last 2 hyper. pistons we have are the stock 400 pin size. The last 2 hyper pistons also are design to be a 9.5:1 comp ratio with either a aussie 302 head or the stock 400 head.
I think (???) we have nailed down most of the popular options for the 400.
Of course we are always looking for other ideas.
Old Aug 4, 2006 | 01:47 PM
roger dowty
so what about those going with a 255 or similar cam? I don't see how the dcr is going to work with 9.5 cr. Do they have to have them dished more?
Your build thats on the site had a cam that drained what .5-.7 of a point more than a 255 similar cam?
thanks
Old Aug 4, 2006 | 05:32 PM
Socketman's Avatar
Socketman
Tim.
What is the weight difference between a stock down in the hole piston and your "0" deck. I wonder is this is what ford may have been trying to do,that or they are just stupid lol.
Old Aug 4, 2006 | 07:31 PM
battered_bronco
stock 1.67
replacement 1.65, oddly the same height as a 351c replacement both vary
TMI 1.72
so roughy from stock .05 from most replacement slugs .070
ford dropped the original flat top down the cylinder to reduce compression and shot them in the foot with the event of crap gas and emmisions regs from the 70s and the tendincy to ping they had to dish the pistons to drop the compression more, retard cam timing and starve the motor
sorry on posting i noticed weight Q not height..oops
now the 400 is a low rev motor usually done the power band by 5000-5500
also the 351m has a huge heavy slug of ~1.92 compression height
the 351Wheezer ~1.75
Old Aug 5, 2006 | 01:48 AM
roger dowty
So has anyone used 9.5:1 cr with a low duration cam like the 255deh or sim? Wondering how that works.
Old Aug 5, 2006 | 02:03 AM
  #28
Brian S's Avatar
Brian S
"Of course we are always looking for other ideas"
Have you given any more thought to the budget stroker kit I mentioned?
Offset grind 4.17 stroke, 240 I6 rods & ACL 1.405-1.415CH pistons.
KB used to make a FT piston that would work with this application. 4343H if my memory serves.
What I'd really like to see is a new budget dished piston so you could use a closed chamber head and not end up with 13+:1 compression.
Old Aug 5, 2006 | 09:40 PM
  #29
TMI's Avatar
TMI
Brian,
Have you looked at the compression ratio chart?
http://www.tmeyerinc.com/pistoncompare.html
Old Aug 5, 2006 | 10:42 PM
  #30
Brian S's Avatar
Brian S
"Have you looked at the compression ratio chart?"
I just did now. What did you want me to notice?
