Aerostar Ford Aerostar
Rear brakes problem!
Old Jun 7, 2006 | 12:07 PM
ken1mod's Avatar
ken1mod
Originally Posted by Pablo-UA
I dont know? What is the valve on this photo? There are no wires there! What is inside?
Rubbery, rusty, metally, springy thingies. probably rusted to heck
Ken
Old Jun 7, 2006 | 01:54 PM
Pablo-UA's Avatar
Pablo-UA
How to dissassembly it? How this valve works? Have you any links?
Old Jun 7, 2006 | 03:07 PM
96_4wdr's Avatar
96_4wdr
Pablo,
Aeros prior to 1990 did NOT have RABS, so there is NO controller or special solenoid RABS valve
your valve in photo is your proportioning valve....there is a shuttle piston inside with a strong spring in that screw on end cap....end cap has a small rubber plug in a hole in the end
spring and rubber plug like to fly off when removing
valve probably plugged with water, line rust and general road crud.....
remove and clean
if there is any corrosion on piston surface, replace unit
line out bottom runs to back brakes
can replace with proportioning valve off another vehicle as long as fittings are correct, can replace fittings
easiest is to find '80s Ranger, F150, Explorer, Bronco but they will probably be corroded also
Old Jun 7, 2006 | 03:30 PM
ken1mod's Avatar
ken1mod
That looks right to me too. Aren't these valves calibrated for each class of vehicle though. My experience is that these valves do not last well and are not a good salvage yard item. My thought is to replace with new. the adjustable valve is still a viable option. I think they are available is sverdlosk or somewhere in Kamchatka.
Ken
Old Jun 8, 2006 | 03:22 AM
xlt4wd90's Avatar
xlt4wd90
There is a valve on all the russian cars. It is on body near rear axe and connected to it by metal arm. I can see no valve on my aero!
These were available on older large vehicles here in the USA. It was an early form of mechanical RABS that made use of suspension motion induced by forward weight transfer to reduce pressure to the rear brakes. They stopped working when the springs started to wear out, allowing the suspension to sag. I think their use were discontinued when we started to get electronic ABS. If you can find a vehicle with one of these in you rlocal scrap yard, you might try adapting it to your van.
Old Jun 8, 2006 | 06:59 AM
Pablo-UA's Avatar
Pablo-UA
It seems to me the best way - to reajust my valve using other springs! But first, I want to dissasembly my and to see what is inside?
Old Jun 9, 2006 | 10:31 AM
Pablo-UA's Avatar
Pablo-UA
I tried to dissassembly this valve. There is a valve inside, spring and ring!
May be to try different springs? I will post images a bit later...
Old Jun 9, 2006 | 11:57 AM
ken1mod's Avatar
ken1mod
Pablo,
If you got it apart and is cleanable/fixable, there should be nothing wrong with installing the original, correct spring.
Ken
Old Jun 9, 2006 | 02:08 PM
96_4wdr's Avatar
96_4wdr
rust, corrosion on piston and chamber or water mix hairball brake fluid stew cause most of the problems in proportioning valves....prevent or impede travel of piston controlling pressure/fluid flow to back brakes
can try stretching spring 0.25 cm to start
Old Jun 10, 2006 | 06:08 AM
Pablo-UA's Avatar
Pablo-UA
The valve is taken appart, cleaned and bleeded! Front wheels lock before rear, but right rear locks before the left wheel! So, one problem is solved!~
old blue beast
1983 - 2012 Ranger & B-Series
Jul 5, 2017 11:30 PM
gabyski
Jan 8, 2017 07:31 PM
cookes_72_F100
Jul 22, 2007 09:32 PM
syncrotuff
Nov 2, 2004 01:53 AM
Dr_Doug
Aug 28, 2002 08:42 AM
