1998 Explorer 4X4 not working
I am thinking the consistent flashing 5 to 6 times must be some kind of code. Local Ford dealer says it must be some electrical issue and to bring it in. I think they just want my money to diagnose it. I suspect it is prob just some solenoid that I could replace myself, am I right?
If you end up replacing the sensors dont cut the brown wire that leads from the t-case to the harness. If you open the harness connector you can remove the red plastic insert and that releases all the wires so you can easily replace the sensors. I may have part numbers written down somewhere for the sensors. If you need them let me know and I'll see if I can find them.
------- 4X4 --------
AUTO HI LO
I installed an overhauled Tranfer Case from the Vendor Ford Dealers use, appx 6,000 miles ago and 2 years ago. I had no problem at all until recently. On rare, RARE occasions, the 4X4 lights will flicker while in AUTO mode. Operation is normal when it occurs, nothing unusual occurs and it goes away as fast as it came.
A couple of months ago, a new symptom appeared. Again in AUTO mode, at very low speeds and only when going into 1st or Reverse and always with wheels cut fairly sharply, you can hear what sounds and feels like the 4X4 trying to engage. It only occurs with cluth fully depressed, and as you let out the clutch, you can hear the the transfer case working to engage (as you are still rolling), followed by a solid clunk and lurch, if you continue to let the cluth out. The lights on the dash do not come on when this occurs. This is very hard to get to repeat. I obviosly now, keep cluth in, stop and shift to neutral, whenever I sense this. This immediately stops the action that is occuring. It may not repeat again for another week or so.
No codes are present. Transfer case is fully serviced. All tires are new with equal pressures. The cluth control ,master cyclnder is fully serviced and works quitely and smoothly. I really do not suspect this transfer case, with such low miles since overhaul, although I am aware it cannto be ruled out completely. The 4X4 feature works fine and lights react normal when using 4X4 feature. I have never used the 4X4 feature, except for when I installed the overhauled unit, and now for troubleshooting, and only in my driveway. I basically baby this EXP.
The comments on the shift motor and possible syncing problems, and the speed sensors from AQUANAUT20 are what caught my eye. I am only aware of 2 speed sensors on my 1997..one in Transfer Case and one in the Rear Axle housing. I installed a new one in Trasfer case, and I have proven the old one is fine. I will look for the other sensors mentioned. I haven't replaced the one on in the rear axle housing. If I recall, I had to reuse my shift motor when I installed the overhauled TC.
Any additiional info anyone may provide would be greatly appreciated. THX ALL!
Read this article and follow the steps to correcting the T/C shift problems
http://members.aol.com/racsan99x/Fix...ansferCase.doc
I found a pic I took of my borg warner 4405 as removed from my 1997 exp sport 4x4, 5 sp manual, with all the accessories removed. I tried to cut and paste it here, but no success.
Anyway, to my supriseIi could see there are TWO speed sensors pads located on the rear side of case! One is easily visable from under the truck. It is located in just under the rear drive shaft output flange at appx 7 o'clock as viewed from rear.
The other, which I was not aware of, is very hard to see from underneath truck. It is located just above the shift motor! The shift motor blocks your view.
I see a lot a post talking about the sensor located in the rear axle. From what I have read and understand, this 3rd sensor is for ABS only! The 2 sensors that read the front and rear axles speeds are the 2 mentioned above...at least that is what I see on my 1997 Exp 4x4 brog warner 4405 with manual 5 speed tranny.
Hope this helps some of you. I have replaced the lower one on my Exp and the flashing lights and occasion uncommanded engagement into 4wd (with dash switch in AUTO - 2wd) have not changed. I will now replace the upper one. Will advise.
choose tech library
then down the left side see xfr case motor
step by step to clean the shift motor
