2002 Explorer 4x4 Problem
Old Aug 28, 2010 | 11:09 AM
nagetech's Avatar
nagetech
Hey everyone!
Hope someone here can shed some light for me! My 2002 4x4 hasn't worked in the last year, and would like to finally stop that blinking light in my dash! the 4x4 High light just keeps flashing. Hitting 4x4 High or Low does absolutely nothing for me! No clicking behind the dash or any sound from the under body.
I'm ASSUMING it's the 4x4 control module, but am not sure. Any help would be appreciated!
Old Aug 30, 2010 | 09:14 PM
m350's Avatar
m350
Have you looked for any bad fuse's?,,,under the hood in the power dist. box.
Old Aug 30, 2010 | 09:44 PM
nagetech's Avatar
nagetech
I did check the fuses! I was hoping it was that simple!
Old Aug 31, 2010 | 06:41 PM
rrgone's Avatar
rrgone
Given your symptoms and the fact that it's an '02 it's a pretty good bet that your 4X4 CM is the problem. It's hard to throw a $175 (online) part at a problem without being sure, but if you take it to the dealer and have it repaired they will want about $500. I have read about some folks finding the correct module on ebay for under $100, but there is always risk getting a good part that is correct for your year/make/model.
Good luck, let us know how you do.
Old Jan 23, 2011 | 11:29 PM
r1enthusiast's Avatar
r1enthusiast
check the wiring by the shift motor. sometimes the ground wire brakes and or the terminals get corroded. disconnect the connector check terminals and look for a broken wire. let us know what you find
katruck
Oct 31, 2014 08:26 AM
Force4000
Jul 9, 2014 08:41 AM
caddy
6.4L Power Stroke Diesel
Apr 5, 2014 01:23 PM
02 Super Duty Guy
Nov 18, 2013 04:55 PM
bcg
Dec 23, 2009 09:13 AM
