cut it out man
Old Jan 13, 2002 | 04:04 PM
dickboyd69's Avatar
dickboyd69
cut it out man
I have a 71 f100 w/a 390. my problem is that when im driving my truck it will sometimes start to cutout all the sudden. I have noticed it will usually happen around 3000 rpm in second gear then if i shift into 3rd it will stop for a couple of seconds but then it will start again untill it gets so bad that i can't go faster than 20 mph. I have no idea as to what is causing this. Has anybody else had this happen to them. what is making it do it only sometimes? Any help is appreciated.
Richard
Old Jan 13, 2002 | 04:50 PM
AaronW's Avatar
AaronW
cut it out man
My truck was just doing the same thing. I thought it was the vaccuum advance. I couldnt get it off, so I just replaced the distributor with a spare I had. Problem solved.
Aaron
Old Jan 13, 2002 | 04:51 PM
sparky's Avatar
sparky
cut it out man
OK quick guess.... partially plugged fuel filter.
Sparky
Old Jan 13, 2002 | 05:54 PM
Bruce in SC's Avatar
Bruce in SC
cut it out man
Point gap too small? Too much play in distributor shaft?
Bruce in South Carolina
1977 F-100 Ranger XLT
1984 Volvo 245 Turbo - it's a Ford now!
Old Jan 14, 2002 | 01:21 PM
dfisher1's Avatar
dfisher1
cut it out man
Adjust your points!
KingFisher
Old Jan 14, 2002 | 01:46 PM
79fordslug's Avatar
79fordslug
cut it out man
Similar problem a few months ago and it was my coil.
Old Jan 14, 2002 | 11:20 PM
tongie607's Avatar
tongie607
cut it out man
Old Jan 15, 2002 | 04:47 PM
dfisher1's Avatar
dfisher1
cut it out man
All,
Coils will fail with temperature. The usually fail because:
1. Someone overtightened their bracket and crushed them.
2. Someone left the bracket loose and vibration wore a hole in it.
Points give up when they rev too high. The worse they are adjusted the sooner they fail.
Intermittent failure of the ignition system not related to temperature is one of two things.
1. Stator pickup in distributor
2. Condenser in distributor
This is a general statement and not always accurate.
Good luck, Have Fun,
KingFisher
Old Jan 16, 2002 | 04:54 PM
martinb's Avatar
martinb
cut it out man
I vote for the fuel filter also. I've had a 77 and a 78 both with this problem, and both had to have the fuel tank replaced to cure it.
