351m electrical problem?
Old Jun 4, 2006 | 05:27 PM
delight's Avatar
delight
Unhappy 351m electrical problem?
I have an 81' F250, with a 351m. A 1 1/2 ago or so, the engine was running rough, couldn't get any speed up. To make a long story short, I ( or my local mechanic ) have changed plugs, plug wires, distributor cap, coil, and a few wires. I have had the carb rebuilt, changed fuel filters, and put stuff into the gas tank to get rid of any water. I watched the engine at night, and found a wire arcing, have found a cracked plug, and replaced ground wires, from body to block. It ran much better, but I could still feel it just didn't have the oommff it should. I could still feel a bit of roughness. After not using it for a couple months, I filled it up, was on my way to move some rock for a friend, and It would hardly run. Just to get a couple blocks, I had to feather the throttle, and had absolutely no power. I pulled over and it stalled. Every time I started it, I couldn't rev it up much, and then it would die. Lots of blue smoke from both the exhaust and the carb. I was able to limp home.
I have since checked the fuel supply, and that all fine. But now it won't even fire. Checked the spark at from the coil, at the distributor cap, and saw a weak spark a couple times. I'm wondering if the Duraspark unit could be causing this, and maybe has been malfunctioning for quite a while? I really don't know anything about that unit, whether or not it either works or doesn't, or if it could be partly working. I've been so frustrated at not having a smooth running motor with all its power. (I forgot to mention that I also had the heads done.). I'm tired of spending money on my mechanic, when nothing seemed to work to make it run really smooth when accelerating, and climbing hills with a load.
Anyone out there have any experience with this ongoing problem?
delight
Old Jun 4, 2006 | 11:52 PM
Bdox's Avatar
Bdox
After all that you have replaced, you are left with the Duraspark module or the distributor. Do you have a spare module on hand?
Old Jun 5, 2006 | 01:07 AM
delight's Avatar
delight
Red face 351m electrical problems
thanks for your response
I do not have a module kicking around. to be honest, it is one part under the hood that I had no idea what it did. I imagine they are available. Any idea how much they are? As I had said, I had repaced the dis. cap. but not the whole distributor. Could that be causing the symptoms I've described?
Delight
Old Jun 5, 2006 | 02:16 AM
Bdox's Avatar
Bdox
Probably around $25-30. I carry a spare for back country trips.
pickenspolitics
23
Dec 17, 2013 04:28 AM
Tonyf250ranger
Mar 14, 2013 12:10 PM
amphiduck
Oct 28, 2012 11:54 PM
TallGuy_Az
Electrical Systems/Wiring
Feb 5, 2009 11:08 PM
Matts72
Sep 27, 2006 09:41 AM
