351M won't idle
Old Mar 11, 2013 | 05:16 PM
Tonyf250ranger's Avatar
Tonyf250ranger
351M won't idle
Last weekend as I was driving on a slightly uphill road, my 1977 F-250 351M 4-Speed just flat died. I thought I had somehow ran out of gas, so I added some and it was able to start up but would not idle. I was able to get it home by keeping the rpms above idle. About 3 months ago I replaced the carb with a Holley 650 double pumper and the ignition system with a MSD distributor, coil, 6a, and wires. I've had no problems until now. It's getting a good 7 psi for fuel to the carb. The vacuum lines look solid. I swapped the coil out with one off my car with no improvement. I've cleaned all corrosion off the cap and replaced the spark plugs, since I figured it couldn't hurt. It runs when I give it gas, but as soon as I let off, it will putter out and die. Is there anything else I can look for or try?
Old Mar 14, 2013 | 12:10 PM
BuzzLOL's Avatar
BuzzLOL
.. Possibly a backfire blewout the power valve(s)... failure prone MSD ignition not giving spark at low RPMs... vacuum leak at under carb. gasket... since vacuum hoses all on and not split, may have developed a vacuum leak in vacuum HVAC controls(if present), power brake booster, carb. vacuum pots(if present), or distributor vacuum advance... ignition advance may be frozen in advanced position... dirt/rubber hose crud in carb. idle passageways... a test vacuum gauge may shed some light...
burkhart3
Nov 8, 2017 09:02 AM
LJForrist
19
May 24, 2016 03:17 AM
lvin4jc
21
Aug 23, 2011 10:15 PM
sammycooks
13
Mar 1, 2010 04:56 PM
melisa
Mar 19, 2004 08:37 AM
