Modify Stock Intake
Old Jun 4, 2006 | 10:39 AM
hllon4whls's Avatar
hllon4whls
Modify Stock Intake
Nearly everyone agrees that the intakes will make more power.
Has anyone modified the stock intake? I took mine off yesterday and looked at it for a while. I cranked the truck up without it and it backfired once when I revved it a bit. Didnt do it again, but after reading about a lean condition, that is probably not the way to go. This was still breathing through the stock filter but with out the long crazing tubing.
I dont have a good feeling about the stock filter, but the main problem with the stock intake seems to be the spot where it goes into the fender. That is a tiny hole. The rest looks ok. Inside looks smooth and decent radius. Also anyone that has ever had the stock tube off, they know it has 1/4 holes drilled in it at various locations. For what reason, I have no Idea.
Old Jun 4, 2006 | 11:40 AM
GMtoFord's Avatar
GMtoFord
I would think those hole's would be for water draining to keep it outta the airbox when you hit a deep rut with water in it..
Old Jun 4, 2006 | 03:11 PM
umdstang's Avatar
umdstang
I took the end piece off the end of the intake tube( the smaller part that goes into the fender), it didnt make a huge difference but i think that it may have made a small difference in taking off easily, it seems like it doesnt take as much peddle to get up to speed.
Old Jun 4, 2006 | 05:06 PM
hllon4whls's Avatar
hllon4whls
How the heck did you get it off? I tried and couldnt make much progress. My truck only has 900 miles, so I didnt want to tear it up, but that thing seems to be on there!
Old Jun 4, 2006 | 08:03 PM
umdstang's Avatar
umdstang
After i pulled the whole intake off, from the airfilter to the fenderwell, i just pulled towards the front of the truck, then i had to take a flathead screwdriver and pry apart the tube where the acordian part to the solid part, i kept pulling the screwdriver around the outside of the tube, it was a pain.
Old Jun 4, 2006 | 10:59 PM
Rancheroracer's Avatar
Rancheroracer
Looks like if one takes that end off you could use an elbow & route to the large square hole next to the radiator behind the headlight which is open to the grille. Seems like that would at least let cool air in? Has anyone thought about trying that?
Old Jun 5, 2006 | 12:14 AM
exiled's Avatar
exiled
yes i've thought of this. in the middle of building it i got to thinking about air swirling at the elbo. so then i started planning on a dual line coming out to both sides. now i'm working on biulding a shorter version that will fit under a ramair hood, in which i'll make functual.
for about $250 airraid and k&n have good modded intakes.
Old Jun 5, 2006 | 07:40 AM
derek4343's Avatar
derek4343
those little holes are for the air to circulate into the baffles and make it more quieter.
beel61
Modular V8 (4.6L, 5.4L)
May 20, 2009 07:10 PM
BajaRacer41
Nov 27, 2007 05:40 PM
rollinXplorer
Feb 26, 2005 12:12 PM
dbf582
2004 - 2008 F150
30
Feb 24, 2005 11:59 AM
Toreador
2004 - 2008 F150
Nov 11, 2004 04:21 PM
