Offroad & 4x4
I NEED HELP!!! Excursion driveline vibration.
Old Jun 3, 2006 | 11:59 PM
Gary4747's Avatar
Gary4747
Ive never used this site before, so please bear with me. I am having an incredibly difficult time trying to pinpoint this loud, agressive vibration that my 2000 Excursion has. Its lifted 10 inches. The majority if the noise seems to be coming from the transfer case, so I replaced the unit. The noise didnt change a bit. It comes anywhere from 40 to 60mph, and only on decel. It sounds just like a bearing grinding. At first, I thought that for sure my pinion bearings were done. Not so. All diff bearings are good. If I continue to decel, the noise/vibration will slowly decreace until its gone at about 35 mph. I can duplicate it on a hoist, but only with the driveshaft installed. It wont do it without the driveshaft. I tried changing the pinion angle, slightly lowering the transfer case, had my driveshaft balanced, U-joints replaced, but nothing changes this growling, grinding chatter. Its so loud. The slip yoke is tight and not worn or stretched out. Has anybody ever heard of such a situation?
Old Jun 4, 2006 | 08:21 AM
fishmanndotcom's Avatar
fishmanndotcom
are you runnnin a CV joint on one end of your driveshaft? (two u-joints next to each other on one end of the driveshaft)
if not you may need one with that much lift, if you do have one you may need to service or even rebuild the CV head
-cutts-
Old Jun 4, 2006 | 09:19 AM
JeremyH's Avatar
JeremyH
You definitely need a driveshaft with a double cardan joint at one end an a slip joint in the middle.
You can get rid of the bad driveline angles by either lowering the t-case outputs (drop the skid from the frame), raise the engine (extended motor mounts), or get a fixed yoke kit for the t-case output.
Old Jun 4, 2006 | 04:49 PM
Skipped_link's Avatar
Skipped_link
I will have to agree that it sounds like you are running the single joint drive shaft, having a drive line built with a double cardan joint will fix your problem, My 03 is a supercab short bed with an 8" lift and had the same problem, the double cardan joint was the fix for me,
Old Jun 4, 2006 | 05:04 PM
JeremyH's Avatar
JeremyH
BTW, this list is in order of increasing cost.
Old Jun 4, 2006 | 06:53 PM
Gary4747's Avatar
Gary4747
But could a drive shaft angle problem really cause a chattering or grinding sounding vibration?
Old Jun 4, 2006 | 07:30 PM
JeremyH's Avatar
JeremyH
When your u-joints were replaced, were they bad? That DS angle could be killing your u-joints quickly.
Old Jun 4, 2006 | 11:26 PM
fishmanndotcom
yes very much so esp if they angle is so extreme the shaft ears are hitting on the yoke. you said that the sound went away when you took the d/s out so try a new shaft with a CV on it
-cutts-
Old Jun 21, 2006 | 09:05 PM
JIMRSX's Avatar
JIMRSX
Gary, did you get it fixed?
RSCHAP1
Mar 25, 2017 04:23 PM
jereli
Nov 20, 2016 10:49 PM
Jointasset
Jul 5, 2016 08:24 PM
Mattyhawk
Apr 25, 2016 08:40 AM
sunogbahay
19
Mar 18, 2011 01:49 PM
