Stone cold heater core.
Old Jun 3, 2006 | 12:31 AM
pmasley's Avatar
pmasley
An easier way to tap the current would be instead of using the switch in the dash would be to tap the circuit going to the compressor. Anytime the compressor is on, no coolant flow. You may want to put a cutout switch on it to control it for winter driving. The compressor needs to be run occasionally in the winter to keep everything lunricated.
Old Jun 3, 2006 | 12:33 AM
monsterbaby's Avatar
monsterbaby
The compressor also runs when you are using defrost, so not a real good choice I am thinking. But there might be a way of doing it so if the controls are in the AC position it would activate the valves.
Old Jun 3, 2006 | 12:43 AM
MRBASS's Avatar
MRBASS
Theres supposed to be a line you can tap into over on the pass side,I think near the vacumn pump that will work a valve..One of the sponsors carrys a kit to do it.I'm thinking ITP but I could be wrong.It's about 40 bucks. I just did the old fashioned style gate valve.
GreatNorthWoods
21
Oct 10, 2012 09:46 AM
duphofff
Dec 21, 2011 05:49 AM
Beatertruck
27
Sep 8, 2011 11:54 PM
jimmyb08SD
EcoBoost (all engine sizes)
Apr 25, 2011 10:30 PM
cdrmotorsports
Sep 3, 2010 12:02 PM
