Header Wrap
Old Jun 1, 2006 | 11:19 PM
shadowdd's Avatar
shadowdd
Header Wrap
Has anyone wraped the headers on a v-10? I was wondering if the normal improvments would occur.... cooler engine bay for cooler intake temps?
Thanks, again
Bryan
Old Jun 2, 2006 | 12:50 AM
aklim's Avatar
aklim
I tried header wrapping once. Never again. I would think that if you were to get some good headers, it won't be necessary.
Old Jun 2, 2006 | 01:32 AM
Monsta's Avatar
Monsta
Sit. Stay.
I always thought that wrapping headers on a street vehicle can lead to increased corrosion. But I'm no expert!
Headers in general usually create less heat in the engine compartment when cruising anyway, right? Due to their ability to move gasses faster.
And aren't you taking air from the outside of your engine compartment or did you do one of those aftermarket "suck-the-hot-underhood-air-in" mods?
Old Jun 2, 2006 | 09:45 AM
shadowdd's Avatar
shadowdd
yeah, I am running a K & N filter.
thanks for the reply
Old Jul 12, 2006 | 04:45 PM
Alaskan350's Avatar
Alaskan350
You might want to check with the maker of the header in question because most of them will not warranty their headers if you wrap them. You are probably better off in the long run sending them off to Jet Hot(www.jet-hot.com) or someone similar to have them ceramic coated. you get the same effect as far as lower engine bay temps and better exhaust flow and it does away with corrosion problem.
Zach
IDIoit
May 17, 2017 12:37 PM
Ronnham
All Things Towing
30
Feb 18, 2017 09:45 PM
Federschutz
Dec 16, 2016 12:25 PM
asmith6
Oct 4, 2016 04:19 AM
Macmathews
Jul 11, 2016 10:43 PM
