You might want to check with the maker of the header in question because most of them will not warranty their headers if you wrap them. You are probably better off in the long run sending them off to Jet Hot(www.jet-hot.com) or someone similar to have them ceramic coated. you get the same effect as far as lower engine bay temps and better exhaust flow and it does away with corrosion problem.
Zach
