PS conversion
Old Feb 4, 2002 | 08:20 AM
AaronW's Avatar
AaronW
PS conversion
I have everything I need to swap power steering into my 69 F250. I remember people saying that you need the driver's side engine perch. I compared the two and they seem to be identical. My parts truck is a 72 F100. Does anyone know why you need the engine perch?
Aaron
Old Feb 4, 2002 | 08:35 AM
red68ranger's Avatar
red68ranger
PS conversion
The PS gear box is a little larger than the manual one and it will hit the driver's side engine perch for the FE engine. If you have another type engine I can't testify to the need to change or not. It cost me a weekend when I did the swap on my '68 F-100 cause I didn't know about the difference. I had everything out and then had to put it all back and go find yet another part. The truck frames come with bolt holes for both perches so you won't have to do any drilling or burning.
Dan Blackwell
Old Feb 4, 2002 | 11:27 AM
rusty68's Avatar
rusty68
PS conversion
[updated:LAST EDITED ON 04-Feb-02 AT 12:29 PM (EST)]as far as the FE engines go, you may get lucky, and already have the correct perch. there are definitely two different ones-
the manual perch has sort of a domed ridge across the top, that the larger p/s gear will hit.
the p/s perch does not have the domed ridge, and actually connects to a different set of bolt holes, farther forward on the frame.
your post doesn't mention what engine you have- i can't speak to anything other than the FE.
Old Feb 4, 2002 | 11:34 AM
buzzard's Avatar
buzzard
PS conversion
Originally in 1968, when Ford started offering power steering, the Bendix unit was used as a direct replacement for the factory manual steering box. Then sometime in 1969 Ford decided to use its own power steering unit (bigger than the Bendix) so a different perch was needed. It sounds like you won't have a problem doing the swap.
Old Feb 4, 2002 | 11:29 PM
AaronW's Avatar
AaronW
PS conversion
Thanks for the explanations. The perches are identical, same bolt positions and all. Just needed that extra boost of confidence.
Aaron
Old Feb 5, 2002 | 06:15 AM
jowilker's Avatar
jowilker
PS conversion
Aaron, I would make darn sure before I loaded the engine that I had the correct one. Like Sam was saying the none perch is straight along the top and the power is deflected towards the front. Hold it in front of of you like it mounts and look across the top, if the lines are straight you have a non power perch. I have one of each and should take a picture so I can splain it better.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Feb 5, 2002 | 07:48 AM
swampystumps's Avatar
swampystumps
Post PS conversion
bsiebert
Jun 18, 2016 12:27 PM
Xcr600man
Ford Truck Parts for Sale
Jan 9, 2016 11:28 PM
Carmax
13
Jul 31, 2015 01:10 PM
66FORDFAMILY
16
May 16, 2014 06:44 PM
crusty77
Oct 5, 2013 07:20 PM
