E4OD backward compatibility
Old Jun 1, 2006 | 09:37 PM
my_first_truck's Avatar
my_first_truck
I have a 1991 5.8L F150 Lariat XLT Super Cab Long Bed with overdrive AT - E4OD. I've heard newer years have major strength/durability upgrades compared to this one. If my transmission has major problems, which years are a direct retrofit (compatible with my ECU, cables, etc)?
Thanks!
Steven
Old Jun 2, 2006 | 12:20 AM
brian_06328's Avatar
brian_06328
I've heard that the E4OD had some major upgrades starting in '95 (made me happy because I heard that after I bought my '95 F250) but I thought that they still used the AOD in the F150's in '91. If it doesn't have the O/D Off button on the shift lever than it's not an E4OD.
At any rate, I would bet that it would be cheaper and much less of a headache for you to take your tranny to a reputable shop and have it rebuilt with any upgrades to strengthen it instead of trying to fit another tranny from a different year truck. That way you would have the strength you want and you know it will fit and work properly.
Old Jun 2, 2006 | 11:25 AM
andym's Avatar
andym
His 91 has an E4OD. An AOD was never offered behind a 351. Too much torque in its stock form.
But, as Brian said, a rebuilt unit is the best way to go. A used trans is not the way to go, as you don't know the history. 20k miles and you could be looking at a new tranny again. If you need to do it anyway, any E4OD from behind a 300, 302, or 351 will fit your truck.
Mustangking1
Oklahoma Chapter
Jul 13, 2014 06:47 PM
Orpackrat
Jun 11, 2014 08:02 AM
fearpb
New Member Introductions
Jul 19, 2013 01:08 PM
stromburg
Washington Chapter
Jan 18, 2013 05:58 PM
sdloe
Sep 16, 2007 03:41 PM
