carb for fuel efficiency
Old Jun 1, 2006 | 07:39 PM
crawlfish's Avatar
crawlfish
will a 1400 edelbrock work in a 302 application?
Old Jun 1, 2006 | 08:19 PM
Kemicalburns's Avatar
Kemicalburns
im an efi guy so how big is that? 600-650 cfm is probably tops
Old Jun 1, 2006 | 08:46 PM
TigerDan's Avatar
TigerDan
Moved at User's request
Old Jun 1, 2006 | 08:47 PM
crawlfish's Avatar
crawlfish
Eddie for my 302
Thanks for the move, Tiger.
I believe 600 cfm, maybe 550... thing is designed for chevy and is jetted at factory for fuel efficiency and not otherwise modifiable in terms of jet kits, I'm told.
Old Jun 1, 2006 | 08:58 PM
TigerDan's Avatar
TigerDan
Well, there you go! If you put a carb designed for a (GASP!) Chebby on a Ford, it will self-destruct!
It's 600 CFM so that's not out of line for a mildly modded 302, but if it's set up for a small block Chevy it's probably jetted a bit on the rich side for a 302 and of course won't have the Ford kickdown linkage, which isn't a problem if you're running a stick.
But check out this article, it has info on setting up that very carb for a Ford:
http://www.mustangandfords.com/techa...1_carburetors/
Old Jun 2, 2006 | 05:57 PM
crawlfish's Avatar
crawlfish
Chebby Carb gibben bedder life onaford
Wow, I am impressed and grateful 2! I do have an automatic, but I believe that I purchased a Ford linkage with it.
Thanks much and very glad I posted here!
crawlfish
'79 F250 Camper Special
351M now 400, not yet running
'78 F100 Ranger Lariat
302 2v all stock, running
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
