98 Ranger pulls right
Old Jun 1, 2006 | 02:22 PM
98mkFord's Avatar
98mkFord
Question 98 Ranger pulls right
First post to this site, so I'll give truck information first.
1998 Ranger 4cyl 2WD, 89,000 miles, Reg. Cab, Step Side bed.It has been a good runner....until now.
Problem is the truck pulls to the right badly, even in slow speeds. I have checked the front bakes-they're good and no sticking. Checked back brakes-and they seem ok-probably should have new shoes soon. I have checked the wheel bearings in front, and can find no "play" in them. This pull to the right is so bad that going around a left curve-even slowly-the left front tire chirps. The Power Steering unit does groan a little when turning to the left, but the Fluid is at the proper level with no leaks. Any ideas would be great.Thx.
Old Jun 1, 2006 | 02:51 PM
RangerPilot's Avatar
RangerPilot
You hit anything lately? Sounds like it's out of alignment.
RP
Zach
Old Jun 1, 2006 | 03:55 PM
98mkFord's Avatar
98mkFord
Ranger pulls right
No i haven't hit anything. No potholes. This truck doesn't get much mileage per week as I live 4 blocks away from work.
Old Jun 1, 2006 | 04:18 PM
wendell borror's Avatar
wendell borror
When truck pulls to the right, you have to pull steering wheel to the left, it balances out that way ha ha ! Welcome to the forum. It does sound more like a tire issue, either the algnment is off, or an under inflated tire, or a bad tire. I had a pinto that did that, it turned out to be a bad rack&pinion, but I'm not sure what year they started putting rack&pinion's in the ranger, any body else know?
Old Jun 2, 2006 | 10:13 AM
donaldm's Avatar
donaldm
Tire problem!
Its a tire problem! If you want to verify change tires left to right (front only) and now it should pull in the other direction.
Old Jun 2, 2006 | 02:33 PM
98mkFord's Avatar
98mkFord
Tire problem
Thanks for the suggetions. I will try to change tires and see what comes of that.
Old Jun 2, 2006 | 02:39 PM
Bob Ayers's Avatar
Bob Ayers
Not necessarily. When you swap left and right, both tires will be rotating in the opposite direction. So, it might not pull in the other direction.
Old Jun 2, 2006 | 03:36 PM
donaldm's Avatar
donaldm
yes good point, he might try swap with a rear?
Old Jun 8, 2006 | 01:54 PM
98mkFord's Avatar
98mkFord
Smile 98 Pulls Right
Thanks for all the suggestions. I swapped the front right and right rear, and immediatley steering got better. So had all the tires replaced, and shocks-since the front right was bad. New tires+newshocks=happy truck.
thanks all!!
Old Jun 11, 2006 | 03:37 PM
tk3445's Avatar
tk3445
i had a similar problem like that and mine turned out to be the driver side e-brake was slightly stuck causing it to pull left
glad you got yours fixed up tho
Mitchel Wincentaylo
Jul 27, 2017 09:28 PM
navistarnut
Apr 6, 2017 10:13 AM
1998Ranger25L153CID
25
Dec 12, 2016 11:21 PM
Torgmada
Aug 19, 2011 01:56 AM
Vyper31
Nov 2, 2006 06:49 PM
