2 battery setup
Old May 31, 2006 | 09:11 PM
JaysRanger's Avatar
JaysRanger
2 battery setup
i know that u have to hook the two up goin pos. to pos. and neg to neg. to stay with the 12 v but should i hook like my lights amps and stuff up to the frist one or the 2nd and can i put the 2nd one in like the back are something and just use like 4Ga. wire to go from one to the other
Old May 31, 2006 | 09:46 PM
Franklin2's Avatar
Franklin2
What are you trying to achieve? Lots of starting power for the engine? If this is the case, you can tie the batteries together like you described, but they need to close to each other up front under the hood. 4 gauge wire running from the rear is not big enough.
If you are trying to help your stereo system out, and also would like to be able to run lots of accessories with the engine not running, with no danger of running the main battery down, you could get a battery isolator and the aux battery could be a deep cycle type. The wire running to the front would not have to be as large, and you could mount the battery very close to your amps. The battery being close to the amplifiers will give you the same effect as running the stiffening capacitors. You will have lots of power available right next to the amp.
