engine probably back fired against starter drive and broke the interior dogs or drive just wore out from use.
with key on, test for high pressure fuel spray at fuel rail test point, looks like tire valve....use eye protection and no open flames or sparks....safer to use fuel pressure gauge if you have access to one....some auto parts stores loan or rent out fuel pressure gauges
Yeah' I pulled the front plug and it's sparking and just the 67 code that I started this thread with. I guess I'll have to get around to checking the fuel pressure.
I'll bet it's the Ign. Control Module on the Side of the Distributor.
They go bad do to too much Heat. I gave you a way to do a quick test in your other thread.
