rear end???
Old May 31, 2006 | 04:19 PM
Bronco Chick's Avatar
Bronco Chick
rear end???
Hi...new here, looking for some info. I have an 01 Expedition that I recently purchased. I discovered that while driving, usually hwy speeds, when it shifts there is a vibration coming from the rear end? Usually only lasts for a second or two them stops, but it is pretty loud. I talked to the dealer and they said to try some friction lube, but I would like to get some second opinions. Any help is appreciated. Thanks
Old May 31, 2006 | 07:13 PM
holiday187's Avatar
holiday187
ummm put royal purple in the rear end no friction modifiers needed put it in there and call it a day. of course drain the other stuff out.
Old Jun 1, 2006 | 06:22 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome bronco chick to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 2, 2006 | 07:54 AM
rdross's Avatar
rdross
Had a vibration when I would start from a complete stop. It would only last a short time and seem to go away. Took it to the dealer and they ended up replacing the "Clutch's" in the differential. Didn't know that they were in there. Oh, mine is a '02 4x4 5.4 EB model.
May want to ask about it, they told me that it would have gotten worse and possibly failed.
Old Jun 2, 2006 | 09:40 PM
Jimmygunz3's Avatar
Jimmygunz3
I have a 99 eb expo with 50,000 miles on it and I have the same problem, get a vibration when the trans shifts on the highway,it sounds and feels like I am driving over rumple bumps on the side of the highway. I changed the rear oil and still the same problem. A 4x4 mechanic said that it could be a bad speed sensor in the transfercase. I am not sure what to do.... anyone else have a solution thanks
Old Jun 3, 2006 | 10:27 PM
sguy1's Avatar
sguy1
I don't have a soluition, but I have the same problem !!! Have heard every thing from bad high presure valve in tranny , to rearend cluches. My expy is AWD and I think it feels like the transfer case (Is your truck AWD/4x4 or 2x4/4x4 ?).
Old Jun 4, 2006 | 10:52 AM
rdross's Avatar
rdross
My vibration was definitely in the differential and the dealer's shop replaced the rear end clutch's. Not chep either. Have had no problems since. It is a 2002 EB 5.4 4x4 AWD
Old Jun 4, 2006 | 02:54 PM
brae123's Avatar
brae123
I had the same shutter problem from a dead start. I replaced the diff oil in front and back (4x4) and it took a little while for it to go away. It is not completely gone. I am thinking of switching over to a full syn for the transmission and diffs. I think that will help greatly.
Old Jun 4, 2006 | 04:36 PM
holiday187's Avatar
holiday187
please do it. i didn't have aenough dough for royal purple transmisson fluid but i did get mobil 1 sythetic transmssion fluid. the rest rear end transfer case and front axle have royal purple synthetic fluid.
Old Jun 4, 2006 | 10:40 PM
Jimmygunz3's Avatar
Jimmygunz3
Mine is a awd, I have to change the transmission, and transfer case oil, I am going to go all synthetic and see how that goes
Old Jun 4, 2006 | 11:14 PM
aagitch's Avatar
aagitch
Had the same problem and I put Mobil 1 synthetic gear oil and friction modifier in the rear end and it went away on the first drive following the fluid change.
Old Jun 5, 2006 | 01:01 PM
Bronco Chick
exactly!!!
It doesn't do it when I'm starting from a stop but when I'm driving
It's a 4x4 btw
civicmindeddogooder
Mar 8, 2013 10:54 AM
broncoproblems
1978 - 1996 Big Bronco
Jan 3, 2006 07:32 PM
lectricman
Jan 30, 2005 07:22 PM
RBrendel
Oct 5, 2002 08:24 PM
