rear a/c
Old May 31, 2006 | 10:58 AM
chadwick984's Avatar
chadwick984
rear a/c
Have an '01 expedition that is blowing warm air from the rear a/c. The front still blows nice and cold. Anybody have suggestions as to what I should be looking for in order to repair this? Thanks.
Old May 31, 2006 | 12:42 PM
kaerch's Avatar
kaerch
could be restrictions in the lines. or a blend door problem back there. is the evaporator cold??
Old Aug 20, 2007 | 12:33 PM
genek's Avatar
genek
I have 03 expedition with the same prablem. I checked the evaporator and was cold. Any idea what is the problem?
Old Aug 20, 2007 | 01:44 PM
jwood's Avatar
jwood
Just had mine repaired last month on my 03 EB. I thought it was one of the acutator doors but it turned out to be the "Accumlator" I believe it is called, in the rear AC. The part cost $38 and labor was about $400. It blows icy cold now, works great!
Old Aug 20, 2007 | 09:56 PM
genek's Avatar
genek
Can you check the part name that the dealer replaced? I pulled the actuator out and is working fine.
Old Aug 21, 2007 | 08:52 AM
jwood's Avatar
jwood
Genek;
They replaced the "rear expansion valve" and now it works great!!!
Old Aug 21, 2007 | 01:59 PM
Gutzy's Avatar
Gutzy
genek
There are 2 actuators for the rear system. one is the temp control and the otehr os the diverter for the ceiling or side vent. I had to replace both of mine. Did it my self with out removing the side panel. The tray in the top of the side panel and the front cup holder pop out. you kind of work blind to to r&r the front actuator.
Jim
Old Sep 10, 2007 | 11:08 PM
genek's Avatar
genek
Thanks for the info. I got the "rear expansion valve" from the dealer $37 To do this job i had to remove Q. pannel is working great thanks
Old Jun 7, 2008 | 04:33 PM
HobieCat17's Avatar
HobieCat17
How do I check the rearexpansion valve on my 99 Expy rear a/c? Thanks.
muneeb
Apr 25, 2016 07:45 AM
5504x4drwcrew
Oct 16, 2011 09:42 PM
Ricky Mayo
Sep 28, 2010 09:05 PM
chaneyb
Jun 21, 2005 03:42 PM
moonjabber
Jun 28, 2004 11:42 PM
