E4OD hemorrhaging transmission fluid.
It could also be coming from the dipstick tube or boot where it plugs into the transmission case. Or even a badly leaking pan gasket at the right front corner.
You will need to get a look under it. Make sure its in park and the brake is set.
Steve
'95 Clubwagon XLT
Sometimes if the tranny overheats a lot, it will leak fluid out of the bellhousing from the seal. Most of the time when things cool down the seal will work fine again.
Could be other things if it isn't leaking from the housing.
Good luck,
Jim Henderson
Have you identified the source of your leak yet? I also am trying to figure out where my E4OD is leaking from. Just finished replacing the front seal (thought sure that's what it was) and it leaks now just as much as it did before. My trans will only leak when driving at above idle. Will not leak if idling in park, drive, or reverse but when you start driving down the road, will leak like a seive.
I can only figure that: 1) I screwed up the new seal I put in, 2) the torque converter may be leaking (although I did check the drain plug in the converter), or 3) the front plate that the seal is pressed into is leaking around the outside edge where it mounts to the front of the trans. I'm sure it's coming from the bellhousing area and those are the only 3 things it could be (I think).
Thought I would share my observations with you to maybe help diagnose your problem.
Please post a reply once you determine the source of your leak.
thanks,
aceryas
Obviously, a bad front seal. The neck of the torque converter where the seal rides can actualy crack. The pump body can leak from its O-ring where it fits into the case.
From your symptoms, leaking at anything over idle, I suspect you have spun the pump bushing. This is the bushing that fits in the pump and supports the neck of the torque converter. The pump will have to be pulled out to check this and install a new bushing.
Steve
'95 Clubwagon XLT
Thanks for the feedback.
When I had my trans out, I looked at the neck of the torque converter. I was looking mainly at the condition of the seal journal but didn't notice any cracks.
The bushing you mention, is this the bushing that is pressed into the front plate (same plate front seal is pressed into, only right behind seal) or is there another bushing further back in the transmission? This front bushing looked fine, actually debated replacing it, but since it looked OK (not scored, spun, etc.) I thought I would take a chance, DOH!
I plan on pulling the trans AGAIN and thought I would try to get as much info this time as possible. Does anyone know where to get a diagram, exploded view, etc of an E4OD transmission?
Clay01, sorry if I highjacked your thread but hopefully some of this info helps you out as well.
thanks again
When you pull it out the next time look for evidence of where the leak is coming from. Look for traces of fluid from the front seal, arround the edges of the pump, etc... If its coming out of the bellhousing then its either the front seal, torque converter neck or its the O-ring that seals the pump body to the case.
Before you pull it out, I would get under it and find exactly where the leak is comming from. Check the cooler lines, dipstick tube where it pushes into the case, the vent on top, etc...
Thanks again for the quick response.
I'm sure the leak is coming from the bell housing area. I've spent hours already under the truck watching atf drip out of the torque converter drain plug access hole in the bottom of the trans. I wasn't able to determine the exact source of the leak the last time I had it out as there was so much of it everywhere!!!
Thought I would try to "pressure test" the trans to see where the leak is coming from next time I have it out. Thought I would leave torque converter installed so front seal is making contact against the seal journal and apply slight positive pressure (2-5 psi) to the vent tube to see if I can determine where the leak is coming from. Does this sound like a logical idea? Although, 2-5 psi may not be enough pressure as my trans will not leak @ idle speed. I have no idea what pressures an auto trans pump is capable of, what the pressure differential would be between idle and say 2000 RPM, or what the typical pressures the front seal would see for that matter. I doubt the front seal would ever see full pump pressure as I assume the drain back hole right behind the seal bleeds pressure back to the pan. Please correct me if I'm wrong though.
Stuart1 - thanks for the effort, but you were right - too small to read. I think clubwagon answered my question about the number of bushings in the front of the trans (this is what I was wanting the diagram for anyway).
Thanks again guys for your help.
PS. if you ever have a transfer case question, feel free to drop me a line. I know a heck of alot more about transfer cases (I work for the co. that makes them for F150, navigator, expedition, explorer, & ranger) so maybe I can reciprocate the favor.
The pump has to come out and apart to replace the bushing. You will also have to replace the front seal again.
Steve
'95 Clubwagon XLT
