460 intake replacement problems
Old May 30, 2006 | 08:34 AM
gsutphin11's Avatar
gsutphin11
I have a 76 460 with all the EGR stuff. I am replacing the stock intake with an Edelbrock Performer w/EGR. On my stock intake, to the left of where the carb would be, there's something bolted on with two steel tubing lines coming out of it, which I think was connected to the EGR. The problem is that there is nowhere to bolt this thing on the new manifold. Am I just going to have to do without it?
Old May 30, 2006 | 10:27 AM
monsterbaby's Avatar
monsterbaby
that is most likely your choke heat riser tubes, you don't need it if you don't have a factory choke on your carb. They used heat coming from the exhaust crossover to pull the choke off instead of an electric choke.
Old May 30, 2006 | 10:31 AM
gsutphin11's Avatar
gsutphin11
Oh, that's good news. I've got a new Edelbrock 750 that I'm putting on. Thanks.
Superdave
13
Dec 26, 2019 04:04 PM
HonestEngine302
Jul 17, 2011 10:27 AM
1980 Ford F-250
24
Apr 13, 2011 05:45 PM
fallconroe
Dec 5, 2008 10:49 AM
EconoMan66
Sep 28, 2007 07:12 PM
