no mo air !!!!
Old May 29, 2006 | 09:33 PM
ExpeditionNutt's Avatar
ExpeditionNutt
no mo air !!!!
hey all.... it's hotter than heck and the expys air conditioner wishes to not work!!!! when i turn on the ac there is no blowing coming from any vents, only until i turn the switch on the highest setting..... even when using the heat!!! so i ask if anyone has ever had this happen and what was the cure-all for my dispair? thanks again in advance.... ohhh!!! it is an '03 xlt
Old May 30, 2006 | 08:29 AM
shov76's Avatar
shov76
Do you hear the blower motor?. If you only hear it on high maybe the switch is bad.
Old Jun 2, 2006 | 09:50 AM
raykjavik's Avatar
raykjavik
switch relay
Old Jun 2, 2006 | 08:21 PM
ExpeditionNutt
got the expy diagnosed and it came up that the blower motor resistor was faulty..... competent and trusted mechanic replaced it and everything works fine.....ALMOST!!!!! i didn't tell him that the ac was blowing warm/hot air, just that the switch must have been faulty... so now my dumb a_ _ ! needs to know what to be looking for!! Any suggestions PLEASE HELP!!!! thanks
projectSHO89's Avatar
projectSHO89
Most likely the resistor pack, might be the switch itself. Typical cause of failure when only high speed works.
Steve
Old Jun 2, 2006 | 08:26 PM
ExpeditionNutt
projectSHO.... that part is cool now...... the expy just wont give me cool air.... did buy recharge kit to see if that would help.... but being a dummy like i am... don't really know if it would do any good!!! Hell don't even know where to put the stuff in at.
Old Jun 2, 2006 | 09:57 PM
Big Craig's Avatar
Big Craig
DON'T F... with it if you do not know where to put it in
Old Jun 17, 2006 | 05:54 PM
ExpeditionNutt
Talking Got Air !!!!
Thanks to all that helped out with the problem my Expy was having with the A/C. Seems that all we needed was a simple recharge.... no blend door problems(SCARY) no compressor issues or any leaks..... that i know of. Hopefully my ride is ready to go (for a while anyway) before we encounter major issues. Once again.... thanks to all
FTE ROCKS !!!!!!!!
JasonBrod
Dec 16, 2016 10:53 AM
Got sand
Jun 17, 2016 12:15 PM
BillJohnson
Mar 16, 2016 12:32 AM
ironman1977
Jun 30, 2015 11:58 AM
ironman1977
Modular V10 (6.8l)
Jun 22, 2015 09:44 PM
